Undo the back nuts on the gray tube on the back side of the brine piston assembly along with the brass nut up on the injector block.
With the gray tube out of the way then there in front behind the brine cam if you unscrew that plastic part with the holes the or what they call brine valve stem guide..
The brine assembly will then come out of the back plate of the system.
