Results 1 to 9 of 9
Thread: What tub did YOU install?
    DIY Junior Member kali2024's Avatar
    Mar 2011
    NJ
    Default What tub did YOU install?
    Hi, we're remodeling our bathroom and I'm stuck on deciding what kind of tub to get, as in a plain old 60 x 32" soaker tub.
    I like the cast iron but they're not tall enough and am concerned about reinforcing the floor.
    Acrylics are high enough but I'm worried about them squeaking/cracking. Also how the hell can a plastic tub thats a bit more than .125" thick hold that much water without the sides bowing out?
    I've decided to go with either the kohler portrait (acrylic) or mendota (cast iron). That being said,
    What did you install?
    A properly installed tub spreads its load out over a fairly large area, so if the floor is up to specs, reinforcment probably isn't needed. Homes are generally built for at least a 40#/sq ft load. Now, if when they did the plumbing, the chopped through joists against code, it could be an issue. The bigger weight is that a larger tub will hold more water.
    Also, ideally, and to provide the longest, reliable life without hassles, it's good to set the tub in something like mortar, which supports it well, and prevents flex (not necessary on CI, but good to even out the load) and prevents those squeaks.
    When I remodeled my MB, I used a tub from www.jasoninternational.com. This is one of the son's of Jacuzzi, that broke off and started his own company. While most of the tubs are listed as air or water jet, they can also be ordered as plain soakers.
    Mar 2011
    NJ
    Jim thanks for the reply..I'll check out the site.
    American Standard makes an Americast "60x30 that is 19.5" tall. That's a porcelain steel tub with backing.
    A good quailty tub like Maax Acrylic are stiff enough.
    Any of the cast iron tubs are good, the Kohler Mendota is very nice. That's always been one of my favorites.
    DIY Senior Member ingeborgdot's Avatar
    Mar 2008
    Kansas
    We're looking into a new tub as ours is getting old and just wont' clean up well any more. It is a cast iron solid tub but we are redoing our bathroom and just feel a new one is in order. I was looking at acrylic but how easy does that scratch? Are they as durable? I have looked at the ones suggested above and like the look of the Kohler but it is the Kohler Archer. Is that a good one? I wish this were easier but it is a pretty permanent thing, so it better be good also.
    CI is and probably always will be the most durable. Acrylic requires some care - minimizing tracked in sand, only using non-abrasive cleaners (best for CI as well). Either can last a long time, if proper care is taken.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    With the huge range of styles and configurations available....acrylic tubs are the only way to go. So long as they are installed in a proper mortar bed, they will feel just as solid as cast iron.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    DIY Member arfeller's Avatar
    Aug 2007
    Port Angeles, WA
    We recently remodeled our bathroom and installed a Kohler cast iron tub named "Tea-for-two" 5.5' tub. It's 24" deep and makes a great soaking tub. Could not be happier
    Many of the tubs these days have a nice slope on the back side. But, this can considerably shorten the useable area. Many of the older styles were nearly straight up and down, and uncomfortable to try to lay down in. Many of those designs have a large amount of area underneath to allow the same design to be used with either an air tub or jetted tub. So, depending on how tall you are, a longer one is always nicer if you really want to soak. I went with a 6' tub, but really would have liked to be able to stretch out in say a 6.5 or 7' tub!
  1. Install of PRV
    By rockpile7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2010, 12:44 PM
  2. 240 v install
    By rockycmt in forum Electrical Forum discussion & Blog
    Last Post: 12-30-2008, 03:27 PM
  3. My Pex install
    By cybervex in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2008, 01:01 PM
  4. Help! Tub Install
    By BSwanson in forum Shower & bathtub Forum & Blog
    Last Post: 07-08-2006, 06:58 PM
  5. Tub install
    By Illtryonce in forum Shower & bathtub Forum & Blog
    Last Post: 11-19-2005, 04:50 PM
