Results 1 to 8 of 8
Thread: A little setup help!
    DIY Member bassadict69's Avatar
    Oct 2010
    Benton, La
    Default A little setup help!
    Right now, the lake I live on is about 4 ft low so I would like to go ahead and set up a lake strainer and whatever else I need and plumb it up to my pier where the pump will be sitting. I do know I plan to use a 2 hp pump such as a Wayne WLS200...
    Anyone have a diagram of how to set this up in the lake? Maybe a diagram of what I need & how to set it up?
    Feb 2011
    NW Ontario, Canada
    Why not use a lake strainer that takes a submersible instead. A submersible is more efficient than a jet would be. How far up hill do you need to send the water?
    Oct 2010
    Benton, La
    It will come up about 5ft to the pier...as far as how far up to the sprinklers, I am not real sure how to measure that!
    Feb 2011
    NW Ontario, Canada
    OK, so this is just for irrigation, not for potable water? Guess I should have Googled that model of pump. There are lots of pond filters available with a variety of strainer sizes. I imagine you want to strain out anything that can clog the sprinklers. Just need something that can move 100 GPM.
    I was thinking a submersible pump and intake system like this:
    http://www.coastalpond.com/carry-pum...cc77f2157a0f3c
    Oct 2010
    Benton, La
    Was thinking about simply putting a foot valve on the end of the intake line
    Oct 2010
    Benton, La
    Discharge on the pump I am looking at is 1 1/2"...is that size carried throughout the yard to each sprinkler head?
    You run the large size pipe to the point where it is divided for the control valves. You probably want the "strainer" to be flexible or easily accessed because you will more than likely have to clean the debris from it fairly frequently.
    Oct 2010
    Benton, La
    We are just now getting around to doing this...I bought a 1 1/2hp Flotec pump this morning as well as all my pvc intake and outlet piping and a foot valve for the end of the intake.
    For now, I simply plan to run the outlet piping up to the center of my backyard and mount a faucet type spigot to hook a water hose or two up to. The buried sprinkler zones and such will come later.
    For now, how should I power the pump? I am thinking to just flip the breaker for it to turn it off & on when I get ready to water.
  1. dont know if this setup is right
    By lootnrok33 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-08-2009, 06:15 PM
  2. 2 Furnace setup
    By Pgh_DIYer in forum HVAC Heating & Cooling
    Last Post: 09-13-2008, 02:53 PM
  3. Please comment on this setup
    By max432 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-24-2008, 07:34 AM
  4. two well setup
    By aceto in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-05-2007, 09:13 AM
  5. How's this for a DWV setup?
    By hmmdinger in forum Plumbing Forum Discussion & Blog
    Last Post: 08-20-2005, 02:51 PM
