Thread: Resaurant Sink Drains, did I screw up? ABS vs Copper
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    Default Resaurant Sink Drains, did I screw up? ABS vs Copper
    I went to a restaurant last week and had to rebuild the drain on their bar sink which drains into a floor drain.
    It was 1-1/2" copper with tight 90's and no clean outs. The bartenders keep dropping straws down the drain and clogging them. And there is no easy way to repair.
    I rebuilt the drain long sweeps, clean outs etc.... All good but I used ABS pipes.
    Now that I've walked home and am thinking about it I wonder, about half of the restaurants seem to have copper, and the other half ABS.
    Just because they use ABS does not mean that it's valid.....
    Thanks Mike
    I prefer plastic and ABS for restaurants, at least for in the bar. Copper perforates after a while in those locations.
    Certified Plumber Plumber1979's Avatar
    Jul 2012
    Ontario
    should be PVC DWV SYS 15
    quote;
    SHOULD BE? Why? I have not used a single piece of PVC DWV pipe or fittings in the 40 years I have been in this area, but HAVE installed many commercial and bar sinks using ABS.
    Correction. I did use PVC for a laboratory sink drain because they were using chemicals that melted ABS but not PVC.
  1. screw hole in copper pipe
    By Jackie123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-05-2010, 07:19 AM
  2. Replacing sink drains
    By Alpinist in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-21-2010, 07:12 PM
  3. Can I tie my bathroom sink and utility sink drains together? As well as vent?
    By vinceliberto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2010, 06:02 AM
  4. sink drains
    By mlawrence in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-08-2007, 10:36 AM
  5. Need advice on new kitchen sink drains...
    By Kansasteacher in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-14-2007, 06:51 AM
