Results 1 to 10 of 10
Thread: Minimum distance from trap to sani-tee
    DIY Member techinstructor's Avatar
    Apr 2009
    North Carolina
    Question Minimum distance from trap to sani-tee
    I've read about maximum distances allowed from the trap to the sani-tee (and vent) but I was wondering if there is a minimum horizontal distance that should be maintained. In other words can the j bend be trimmed to a shorter length if desired? We'd be using 1 1/2" pipe at this location. I also have a 2" trap for the washer that will connect to a sani-tee that will not be in the wall. Is there a minimum length for the pipe coming from the trap to the sani-tee and vent?
    Jun 2009
    Canada
    Generally, double the diameter of the given pipe.
    Nov 2010
    Maine
    Twice the diameter of the pipe, elswize you have an S trap
    Writing, constructionDIY Member Yersmay's Avatar
    Sep 2005
    Los Angeles
    I posted an identical question sometime ago and got some very interesting answers. I tried lifting the title of that thread and placing it in this post but I'm not sure it worked. At any rate, the thread can now be found in the Code Question forum, UPC. The title of the thread is:
    trap arm question, UPC.
    If I didn't successfully insert a link to my past thread, maybe someone can do that for me.
    George the Plumber Gsalet's Avatar
    Sep 2010
    San Francisco
    If you can make the connection without cutting into the radius of the trap arm it should be OK, No Minimum sited in the code
    Apr 2009
    North Carolina
    The other thread is at: http://www.terrylove.com/forums/show...m-question-UPC
    I posted the link so to make it easier for others, but I think it just confused me more than it helped. I guess I'll try to follow the 2 x the pipe diameter suggestion, and if that doesn't fit, I'll ask my inspector before going shorter.
    Plumber jimbo's Avatar
    Since the code says 2 pipe diameters developed length from the weir of the trap to the inner edge of the vent, I think in practical terms, it would be hard NOT to meet that spec.
    Dec 2007
    That would be a crown vent not an s-trap.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    Or a crown vented trap if the drain was on the horizontal. Either way it's illegal, at least under the UPC.
    Apr 2009
    North Carolina
    Ok, it is illegal in NC too. After posting this I found this in the NC Code:
    906.3 Crown vent.
    A vent shall not be installed within two pipe diameters of the trap weir.
    Thanks for the responses.
  1. minimum distance from shower drain centerline to joist
    By lwylie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-31-2010, 03:38 PM
  2. Minimum vertical distance from tub bottom to p-Trap inlet?
    By bagdanoj in forum Shower & bathtub Forum & Blog
    Last Post: 10-20-2009, 11:18 PM
  3. Minimum toilet to sink distance
    By prpsrv in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-13-2009, 06:12 PM
  4. minimum distance from walls/ceilings for lighting fixtures
    By nelsonba in forum Electrical Forum discussion & Blog
    Last Post: 10-21-2007, 12:49 PM
  5. Make chrome trap to sani-T connection look nice
    By jwray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-22-2005, 06:52 AM
