Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Converting single bathroom sink to double sinks
  1. #31
    DIY Junior Member My Dream's Avatar
    May 2011
    Ontario Canada
    Picture #12
    This is the frontal view. ABS drain would maintain standard 1/4" per foot slope.
  2. #32
    Right now you have an 1-1/2" drain line for one lav.
    I can't make out on the drawing which way you are intending to drain it.
    Normally you would use a fixture cross and drain out the bottom with 2"
  3. #33
    May 2011
    Ontario Canada
    Thanks for the reply Terry, it's appreciated.
    Yes the builders use 1 1/2" abs for the drain assembly. At present there is new ceramic flooring therefore it would be too costly to rip it up and redo the drain through the floor. The present drain runs horizontal and I'll assume it's already vented to the stack shown in the attic. My plan was to add another vent between the two drain assemblies and run it vertical between the wall and tie back into the main attic vent which is approximately 27" away.
  4. #34
    DIY Junior Member jaydub2010's Avatar
    Oct 2010
    Whidbey Island, WA
    quick question on this subject.. doing some reno work on my parents main bathroom on the second floor of their 80's split level. Their main bathroom has a 72" vanity and is plumbed for one sink. They wanted to put a double sink in so I was going to open up the wall behind the vanity and see what is going on. There is an adjoining bathroom on the back side of this wall which also has a single sink and vanity. I will verify once its opened up but was curious if they would have connected these two sinks and their respective drains/vents? And if so, is it a fair assumption that they would have a 2" drain pipe leading down? If I open things up and find that they're separate systems, I will need to provide a 2" drain pipe down for the new double sink, correct? exactly how far down? All the way to the stack?
  5. #35
    You can't decrease the waste line. It can get bigger, but never smaller.
  6. #36
    Oct 2010
    Whidbey Island, WA
    Hey Terry, which do you think is the better way, using a fixture tee (as in the new construction photo) or doing the fixtures individually (as in the "green background" photo)? In the green background photo, you mention a distance of 42" is that from the sanitary tee's up or from wye to wye?
  7. #37
    If you have a 2" waste, then the double fixture cross.
    If you only have 1.5", then the green background photo. Still not really right, but at least it's all vented, and it should drain out very well. I have done it that way when there is only a 1-1/2" pipe to work with.
  8. #38
    Oct 2010
    Whidbey Island, WA
    Thanks! This site is a big help! And all the discussion are great!
  1. Which drain to use when converting from double to single sink
    By nazrat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-08-2009, 07:41 PM
  2. Bathroom- Converting single vanity to double
    By NewJerseyJC in forum Remodel Forum & Blog
    Last Post: 09-10-2008, 07:12 PM
  3. converting single bathroom sink to double.
    By kevin 71 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-23-2008, 10:55 AM
  4. Converting Double sink vanity to single sink
    By karenwondergem in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2006, 06:17 AM
  5. single to double bathroom sink?
    By nickson5 in forum Remodel Forum & Blog
    Last Post: 12-30-2005, 06:31 AM
