Page 1 of 3 123 LastLast
Results 1 to 15 of 38
Thread: Converting single bathroom sink to double sinks
    DIY Junior Member maxxfusion's Avatar
    Mar 2011
    Cleveland, Ohio
    Default Converting single bathroom sink to double sinks
    I am in the process of remodelling my bathroom. I have a 72" vanitiy with a single sink. I figured since I have the space double sinks would be really nice to have especially with kids. I made this decision late in my remodel project. I looked under the cabinet to check things out and found out that at one time there was double sinks there. So all the copper is in place. Here is my issue. I went to Lowes today and bought some ABS. I can not find the double fixture tee anywhere. I came home and googled the part. I came across the tee at Grainger but its 2 x 1 1/2 x 1 1/2 x 1 1/2. The abs pipe that runs upstairs is 1 1/2.
    So my question is does the double fixture tee i need exist in all 1 1/2? I am assuming i will have to order this online.
    Any help would be greatly appreciated.
    Mar 2011
    Cleveland, Ohio
    I just found a double sanitary tee in all 1 1/2. Not sure if I can use that?
    The 1.5 double santee will be a bear to snake. It would need a cleanout on the vent to clear the center.
    There are also ways to run it using a wye and two santees that would force the snake downhill instead of over and across to the other lav location.
    If I had 1.5" pipe, I wouldn't even bother with a cross, but instead wye off and have opposing santees to to separate trap arms and then revent at 42"
    I know that are come countries that will do it, but they must not have ever done service work. I would love to watch them try to get the snake to drop down the vertical.
    Just found this picture
    Jun 2009
    Canada
    I searched this forum to find this picture from a thread created last year...
    Mar 2011
    Cleveland, Ohio
    My issue is i dont have the pipes exposed. I would need to rip out drywall to do this.
    Can i use this and some 45 degree elbows?
    Jun 2009
    Canada
    How would that be any better than the double santee.
    Look at what Terry posted, do you a see a double fitting of any type there?
    No.
    That type of fitting would need to have vents on each arm. That fitting with a 45 creates an S trap.
    Mar 2011
    Cleveland, Ohio
    How do they do it in new homes?
    2 x 1.5 x 1.5 1.5 fixture cross.
    Double Lav
    Mar 2011
    Cleveland, Ohio
    So if I could find a 1.5 x 1.5 x 1.5 x 1.5 fixture cross I would be ok? I have looked a bit online and can only find the 2 x 1.5 x 1.5 1.5 fixture cross. Since I had the double sinks at one time and only have 1.5 pipe run to the bathroom can I just use a reducer to go from the 2 pipe to the existing 1.5?
    You can only increase pipe size as you drop down.
    You can't decrease.
    Mar 2011
    Cleveland, Ohio
    I was thinking i could add this to my existing 1.5 pipe from the floor. http://www.grainger.com/Grainger/Pip...ncreaser-1WJE5
    Then use a small piece of 2 pipe and connect the 2 x 1.5 x 1.5 1.5 fixture cross.
    I cant do this?
    Jun 2009
    Canada
    You certainly cannot...
    Basic rule of plumbing, you'd be creating a funnel...
    Mar 2011
    Cleveland, Ohio
    Ok thanks guys. I guess I will be removing some drywall and going off of Terrys pic he posted.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    So tell me why you can not use two (2) San Tee's facing opposite directions one three inches lower than the other.
    It would result in about a 3" difference in heights for the two P-Traps but that should not be an issue, and would have a short section of a wet vent.
    Michael
  1. Which drain to use when converting from double to single sink
    By nazrat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-08-2009, 07:41 PM
  2. Bathroom- Converting single vanity to double
    By NewJerseyJC in forum Remodel Forum & Blog
    Last Post: 09-10-2008, 07:12 PM
  3. converting single bathroom sink to double.
    By kevin 71 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-23-2008, 10:55 AM
  4. Converting Double sink vanity to single sink
    By karenwondergem in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2006, 06:17 AM
  5. single to double bathroom sink?
    By nickson5 in forum Remodel Forum & Blog
    Last Post: 12-30-2005, 06:31 AM
