Results 16 to 30 of 36
Thread: Pro's and con's of 4" dia. well
  1. #16
    DIY Junior Member Shooter45's Avatar
    Mar 2011
    MS
    Think he said the pump should do 25gpm.
  2. #17
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    is that a bladder/diaphragm tank (if so, do you know brand?) ..or a galvanized tank?
  3. #18
    Well driller,pump repair. and septic installer Waterwelldude's Avatar
    Feb 2009
    Texas
    A 25gpm 1.5hp pump, and 220 tank. That is the setup I would go with.
    "I shall never surrender or retreat" -Col. William Travis
  4. #19
    Mar 2011
    MS
    Quote Originally Posted by justwater View Post
    Not sure. I'll check tomorrow. Is one better than the other?
  5. #20
    May 2010
    NE FL, SE GA
    i agree.. just wondering if its an actual 220gal galvanized tank or a 220 equivalent bladder/diaphram. .. not that it matters much i guess.
  6. #21
    May 2010
    NE FL, SE GA
    ..pretty much 6 in one hand, half dozen in the other.
    run time is basically the same. galv. tanks just take a couple additional parts to maintain air/water level in tank, but the tanks do tend to last longer. i like bladder/diaphragm tanks personally (preferably flexcon or well-x-trol). just makes things easier if you were ever to convert to a different type system in the future such as constant pressure valves and what not.
  7. #22
    Moderator valveman's Avatar
    Mar 2006
    A 220 or equivalent bladder tank with a 20 to 25 GPM pump is bare minimum. Just barely gives you the minimum 1 minute of run time. Then every sprinkler zone has to match the 25 GPM pump exactly, and while running sprinklers, you don’t have any volume or pressure left for the house.
    Why wait to convert in the future, the future is here. I would use a Cycle Stop Valve and a 4.4 gallon size tank as in the picture to the left. This will be much less expensive and work much better than just a big tank. With the CSV you can irrigate with as little as 1 GPM to 20 GPM without cycling the pump to death, and still have constant pressure and plenty of volume in the house. See this graphic of how it works and why big tanks are a thing of the past.
    www.cyclestopvalves.com
  8. #23
    May 2010
    NE FL, SE GA
    dont tell me, tell the OP. i know how csv's work.
    i was just answering his question on the differences in tanks.
    btw, the sweet little 4.4gal bladder with a csv is bare minimum run time also... without any storage.
  9. #24
    Mar 2006
    One minute of run time is only important with the old style pressure tank only systems. When the system is on for one minute, then off for one minute, on a minute, off a minute, over and over and over, it is important to have a tank large enough to give you that minute. Even then the pump will still cycle itself to death.
    Cycle Stop Valves stop pumps from cycling on and off. As long as you are using at least 1 GPM, the water goes right past the tank, not in and out of the tank. So with a CSV and 4.4 gallon tank, the run time is for as long as you are using water, and not dependent on how big a tank you have. Then after you turn off all the faucets, it still takes the CSV one more minute, to put one more gallon in the tank before the pump shuts off.
    When the CSV is filling the tank at 1 GPM, the amps are reduced, which de-rates the motor. A de-rated motor is running cooler than normal, and really doesn’t need one minute of run time anyway.
    Pressure tanks were never meant for storage, only to reduce the number of times a pump cycles on and off. Even a 220 equivalent tank only holds about 25 gallons of usable water. That 25 gallons of storage would only be important during a power outage, and even then there is no guarantee the tank will be full when the power goes off. There is a 50/50 chance the tank will be half empty when the power goes off. But the real odds are even a big tank won’t have 2 gallons in it when you really need it.
    Your real water storage is in the well where you have millions of gallons stored. If the power is off long enough to matter, you need a generator. If the power is off for a long time, a big pressure tank will be empty in a few minutes. If you spend the money on a generator instead of a big tank, you will have water for as long as you have fuel.
    Those who don’t learn from the past are condemned to repeat it. No need in waiting to see the problems of a pressure tank only system before installing a CSV. Learn from everyone else’s mistakes and get it right the first time.
  10. #25
    May 2010
    NE FL, SE GA
    for the proposed system to be off 1 minute before pump kicking back on, you would be using 25gpm. the pump would not fill this tank and be off in another minute if 25gpm were in demand. storage isnt only important for power outages.. the storage/drawdown says this system will have 24 extra gallons over 4.4gal tank for handwashing, toilet flushing, rinsing, and other household use before the pump has to run again. the csv/4.4 gal will cycle once for each of these applications. small amounts of steady longterm demand and the citylike pressure is the only place the csv/4.4 will shine for a home. as far as power draw, not running will beat reduced amperage every time.
    sure you can run a generator all day and have water for as long as you have fuel with the csv/4.4gal.. or you can fire up the generator 1 minute for every 25 gallons.
    you know i'm a fan of csv.. but i think your reaching to say a csv/4.4 is better suited for in-home use rather than the proposed tank as far as cycling goes. when irrigation comes into play, the tides could turn.. unless the irrigation guy knows how to properly size the system.
  11. #26
    Mar 2006
    OK so a 12 GPM demand will cause the pump to cycle on for two minutes and be off for two minutes. Two minutes is better than one minute, but still cycling the pump to death.
    25 gallons in a tank just means the pressure is decreasing from 60 to 40 for the first half of a shower, then increasing from 40 to 60 for the last half of a shower. You may not realize how aggravating that is if you have never experienced a shower at a constant 50 PSI.
    Unless you wait a minute or two between water uses, the pump does not cycle for every use, even with a 4.4 gallon tank. Flush a toilet, the toilet takes a minute to refill, then the pressure tank takes another minute to fill before the pump shuts off. So if you donít wait two minutes to wash your hands, turn on the shower, or wash a toothbrush, the pump doesnít cycle again. If the dishwasher or washing machine is filling while other appliances are being used, the pump doesnít cycle again. If someone is in the shower while you are washing or flushing, the pump doesnít cycle again. With three girls in the house, the pump will most likely come on about 6:30 AM, and stay on until 7:30 AM, when everyone leaves the house. The pump will probably come on again about 6 PM and run until 8 PM, while washing machines are running and everyone is using water.
    As far as power draw, running for an hour or two a day at reduced amperage might increase the electric bill $3 to $5 a month for just a house. That difference wonít pay for the extra cost of the big tank. Then if the reduced cycling triples the life of your pump, a couple of extra bucks in electricity will actually save money.
    During a power outage, just run the generator for 30 minutes, and tell everyone they have 30 minutes to use all the water they want. Or fill a 25 gallon tank, shut off the generator, and tell everyone to take a sponge bath. Girls love that. Of course you could leave the generator running for 30 minutes even with a big tank. Either way the generator is running if you want to use any quantity of water to speak of.
    And your right all of this changes if you have irrigation. The CSV especially shines by eliminating multiple cycles when you have long-term low uses of water. Irrigation contractors are also learning that properly sizing a system no longer means matching every zone to the pump. Properly sizing an irrigation system means getting the most use for every gallon of water. This means sizing the system for the exact needs of the yard, not the pump, which is what a CSV does best.
    I still use big pressure tanks. But only on a 2,000 GPM system for and entire city like in the pic attached.
  12. #27
    May 2010
    NE FL, SE GA
    impressive setup. thats not a sta-rite signature bladder tank is it?
  13. #28
    Mar 2006
    RO water so the tank had to be fiberglass. I don't really like those kind of tanks but, that is the one the customer wanted, so we made it work.
  14. #29
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    I assume that little pump is what I would call "Gap Action"? Nice color, is that "Goulds Blue"?
  15. #30
    Feb 2010
    SE Texas-Coastal
    I really like that 220 gallon tank set-up. With that tank you should have plenty of draw-down, and when that hurricane comes you'll have tens of gallons of water at pressure stored in reserve. You can flush the toilet several times, wash up a little, etc and the water will run until the pressure reaches zero. So you're "total drawdown" will be much greater than what will happen when the pump is running and set at 30-50. When Ike ran through here in 2008 we lost power for three days. With gas at $3+ per gallon it was nice to have that 10-20 gallons of water extra and not have to run the generator every time a facet was opened up. Charge up the tank once or twice a day if you're conservative. Also add an extra air charge and you can really get that drawdown up. Plus the galv. tank will cut down on the H2S smell.
  1. Connect a fridge. Pro's and Con's of Pex vs Braided Stainless vs Copper vs Plastic
    By geniescience in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-16-2010, 11:29 AM
  2. THANK YOU - Terry and all the pro's
    By SpartyRules! in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-15-2009, 02:40 PM
  3. "Machine Gun" or "Thud" and a Weeping Toilet...oh my!
    By maxxis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2009, 07:38 PM
  4. Need Whirlpool Recommendation from the Pro's
    By Waltman in forum Shower & bathtub Forum & Blog
    Last Post: 10-11-2007, 08:22 PM
  5. Test question for you pro's.....
    By Randyj in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-23-2007, 02:12 PM
