Results 1 to 4 of 4
Thread: Well water tank pressure gauge
    DIY Junior Member Jimrose's Avatar
    Oct 2012
    Virginia
    Default Well water tank pressure gauge
    Had new water tank installed. No pressure gauge installed on new one. Can I install permanent screw on gauge to drain valve (about 10 in. From tank?
    Feb 2011
    NW Ontario, Canada
    You can install a gauge anywhere you want.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Someone would install a tank and not put a gauge on it?
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    likely someone who doesn't want to be called in a month when it lies or quits completely. With most systems being outdoors around here, gauges don't have a very good lifespan. If u know how to read a tire gauge, save your 5$.
  1. Low water pressure, pressure tank gauge
    By epeloke in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-28-2012, 07:03 PM
  2. Water hammer bouncing pressure gauge needle AFTER pressure tank fills
    By hawkhunter in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2012, 10:35 AM
  3. pressurized water tank, pressure gauge problem
    By geny725 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-25-2010, 06:40 PM
  4. Should I Add a Pressure Gauge to A Bladderless Tank
    By Markgc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-20-2010, 04:33 PM
  5. Bladder tank pressure gauge question
    By WV Hillbilly in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-25-2008, 02:20 PM
