Results 1 to 4 of 4
Thread: ABS and hot air ducting
    DIY Junior Member vancouver's Avatar
    Mar 2011
    Vancouver, BC
    Default ABS and hot air ducting
    I'm running 2" ABS across some hot air ducting in a floor between joists. Should I protect the ABS from the heat or does it matter?
    Jan 2006
    Rosedale, Md
    With the temperature that you run heating duct you shouldn't have a problem, I would not lay the pipe on the duct.
    Mar 2011
    Vancouver, BC
    That's what I was thinking. Is there anything I could wrap around the pipe to deflect the heat? There isn't much room between the pipe and duct.
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    If the duct is in an unheated space it really should be insulated. While ABS WILL soften and can deform when heated it will take a lot more heat than it will ever see even a 1/2 inch away from a residential heat duct.
  1. hrv ducting question
    By toddmpa in forum HVAC Heating & Cooling
    Last Post: 01-21-2011, 06:16 AM
  2. Dryer vent/ducting
    By DIY in forum Remodel Forum & Blog
    Last Post: 03-02-2010, 10:50 AM
  3. Ducting question?
    By thunderhead in forum HVAC Heating & Cooling
    Last Post: 03-24-2009, 11:57 AM
  4. Bathroom exhaust fan ducting
    By newowner in forum Shower & bathtub Forum & Blog
    Last Post: 08-17-2008, 12:14 PM
  5. DIY HVAC Ducting?
    By FlyBoyd in forum HVAC Heating & Cooling
    Last Post: 01-19-2008, 05:44 PM
