Thread: I'd like to use flexible hose to connect my trap primers...
    DIY Senior Member speede541's Avatar
    May 2010
    San Francisco Bay area
    Default I'd like to use flexible hose to connect my trap primers...
    I'd like to use a short (~9") piece of flexible hose to connect the bottom of my trap primers to the copper pipe that feeds the traps.
    This would make it easy for me to disconnect the primers for cleaning and servicing.
    Should I just use PEX with the appropriate connections? I'd prefer something more flexible / supple, but in a 1/2" diameter. Suggestions?
    You can use a union, that makes it removable. And PEX would give you move movement then disconnecting a solid pipe.
    May 2010
    How do you like a copper union vs. a disconnectable Shark Bite connector?
    Edit: ...or what about 1/2" PEX just loosely "plugged in" the an open end of a 3/4" or 1" bell? After all, I've got air gaps elsewhere in these lines, so it's not as if they're water tight. In fact, couldn't that eliminate the need for a MI-GAP air gap threaded on to the bottom side of my MIFAB primer?
  1. Can we talk about trap seal primers in residential use?
    By speede541 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-15-2011, 08:54 AM
  2. Opinions on waterless trap primers.
    By karsc01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-01-2010, 02:26 PM
  3. Flexible hose to rough in valve in tub
    By sxotty in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2008, 11:55 AM
  4. Do I need a flexible copper fitting where these lines connect
    By templar2b1ask1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2005, 12:11 PM
  5. flexible hose and connection for a gas grill
    By jadnashua in forum Toilet Forum discussions
    Last Post: 09-03-2004, 05:57 PM
