Results 1 to 12 of 12
Thread: Can mosaic tiles go on the floor?
    DIY Junior Member Ecoman's Avatar
    Mar 2011
    Los Angeles
    Default Can mosaic tiles go on the floor?
    I really love the mosaic tiles patterns...the colors and glaze of it is amazing! i want to install it in my bath but don't know how to calculate the quantity i would need ...actually now that i think about it i realize they came in standard size of 1by 1, so i guess i just need to see how many square footage i`v got.
    So i have this question solved!
    But my next question is - can they go on the floor ...they look so fragile?
    Plumber jimbo's Avatar
    The bigger problem is slippery. Tiles for the floor have a different glaze. Wall tiles tend to be way to slippery for satisfactory use on the floor.
    There are numerous mosaics rated for floor use - this depends on how durable the tile and glaze is. If it is only rated for a wall, then no, do not use it on a floor. A floor rated tile can be used either location, but a wall rated tile should only be used on a wall. Often, the numerous grout lines with mosaics make it less slippery than a larger tile. There is an industry standard for floor tile, I-V (1-5), with V (5) rated for commercial use. This rating has nothing to do with how slippery it is, but on how well it stands up to wear.
    DIY Junior Member Aliza's Avatar
    Dec 2010
    Lakewood, NJ
    You should be able to find a lot of options for mosaic floor tiling. Floor tiles & wall tiles have a different finish so I wouldn't recommend using tiles meant for walls on your floor.
    Mar 2011
    Los Angeles
    got it! so i will use mosaic tile with a different finish for the floor...something not slippery. thanks
    DIY Junior Member moseslove's Avatar
    Mar 2011
    Sun Fernando Valley
    you can find the mosaic tile for the floor here
    Mar 2011
    Sun Fernando Valley
    if you need some ideas
    DIY Junior Member John Shum's Avatar
    Jun 2011
    California
    We just asked this question and received a lot of the same answers about it being too slippery - BUT, we went ahead and did it anyways, and it's been great. Check out our glass mosaic bathroom tile.
    quote; BUT, we went ahead and did it anyways
    A PERFECT example of someone who asks a question and keeps asking it until he either gets an answer he wants, or decides to IGNORE all the expert opinions and do what he intended to begin with.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    After looking at the pictures that floor does look like a matt finish.
    For a given tile size, a mosaic will be less 'slippery' because it has more grout lines, which aid in traction (at least in your bare feet). You must be careful in cleaning the grout during installation to ensure you don't dish out the grout line, though.
    Jul 2009
    North Vancouver, BC
    Default Using small glass tiles on a bathroom floor.
    Post(s) deleted by John Whipple
  1. Floor Tiles & Tub
    By kindajazzy in forum Shower & bathtub Forum & Blog
    Last Post: 09-28-2009, 05:36 AM
  2. Setting mosaic floor tile
    By khayes in forum Remodel Forum & Blog
    Last Post: 04-21-2009, 07:41 AM
  3. Ceramic floor tiles
    By DIY in forum Remodel Forum & Blog
    Last Post: 05-12-2007, 06:32 PM
  4. Tiling over mosaic bathroom floor query
    By et5 in forum Remodel Forum & Blog
    Last Post: 07-17-2005, 06:09 PM
  5. basement floor tiles...asbestos?
    By bozomedic in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-03-2005, 11:50 AM
