Results 1 to 15 of 16
Thread: Leaking water service in front yard. What are my repair options?
Hybrid View
    DIY Junior Member dayster's Avatar
    Jun 2007
    Vancouver, BC
    Default Leaking water service in front yard. What are my repair options?
    I am getting this question out in advance of knowning the size and material of my water service: right now what I have is a hole in the front yard slowly filling with water, and its getting dark so I am putting off fully exposing the pipe.
    I expect to find 3/4" copper, but my house is almost 100 years old so if its the original service it could be something else.
    Anyhow, from what I have been able to tell, I have a pinhole-sized leak. I don't want to replace the service at this point, that will be a major job involving removing a retaining wall etc. etc. I just want a quick fix, recognizing that it may not last forever.
    So... are there ready-made repair couplings or other do-dads that I can buy to handle this problem or will I need to be replacing a length of service and splicing in a new piece with compression fittings, or...
    Any suggestions and help will be greatly appreciated!
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    You have two options, replace the entire line, or hire someone to BRAZE on a repair coupling.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Jun 2007
    Vancouver, BC
    Braze, eh? I presume that would be a brass repair coupling then? I haven't brazed since grade 8 metal shop...
    Aug 2009
    South*East
    If your looking for a temporary repair six months or so, then try a hose clamp with a piece of rubber under it until you can replace the line. If the house is 100 years old chances are it's a galvanized line. If the leak is at a fitting then this method will not work.
    John
    Jun 2007
    Vancouver, BC
    Thanks John, I was thinking that way already. It isn't at a fitting (well, there's no reason why there should be a fitting in this location - tomorrow I will know for sure).
    I am probably looking for a repair good for a couple of years until mega yard reno happens. But its a shallow dig, so no big deal if my el-cheapo repair fails. There's no reason why such a repair should fail, save for the pipe underneath actually deteriorating further.
    Tomorrow I should know what material I am dealing with and will go from there.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    I would recommend using a repair coupling or two.
    I use them all the time for this type of issue. Basically an over sized piece of pipe with a rubber compression sleeve on each end to seal the pipe.
    Use two of them to replace a section of pipe or one to slide over the break. I used one on a 2 inch water main on Saturday. And try to carry two of each size on my truck at all times.
    Michael
  1. Sewer water standing in front yard
    By momisana in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-06-2009, 05:06 PM
  2. PB Yard Service Repair ?
    By theestimator1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2008, 07:33 AM
  3. Water main leaking in front yard
    By titan77 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-14-2008, 05:30 AM
  4. Cracked Flange/Pipe Repair Options
    By Jeff_08 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-26-2008, 08:30 PM
  5. older dishwasher leaking a bit out the front
    By qkrinkle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-14-2006, 07:13 AM
