Results 1 to 6 of 6
Thread: My Watts 800M4QT is leaking and I need to replace the Vent Float.....
    DIY Junior Member FAM's Avatar
    Mar 2011
    Texas
    Default My Watts 800M4QT is leaking and I need to replace the Vent Float.....
    I know they have repair kits for my problem, but do I have to buy the whole kit if I only need the vent float? Where can I get just the VENT FLOAT? If it's not possible to get just the vent float, where can I order the kit for a decent price?
    Any assistance will be greatly appreciated.
    FAM
    Yakima WA
    Back flow prevention devices should be inspected and re-certified annually by a licensed inspector. Texas may not pay attention to the federal requirements on this, but they certainly do in the state of Washington. In my city, those of us using city water for irrigation are provided a list of approved certified inspectors each spring (got my list about a month ago) It is our responsibility to contact one of these and make an appointment for inspection. If the inspector finds a device is not holding, he should have the repair parts necessary to make needed repairs on the spot. We pay the inspector's fee, usually $35, plus any repairs needed. He then sends a copy of his inspection to the city. If we fail to get the inspection, our water is shut off.
    Mar 2011
    Texas
    Default Thanks for the info
    Thanks for the info, but here in TX we don't have that same requirement. We are allowed to do our own repairs for sprinkler systems. Now I just need to find the part or repair kit.
    Yakima WA
    Well, if Texas doesn't enforce requirement for back flow devices, why not just plumb you system without one?
    samson smith
    Guest
    Quote Originally Posted by FAM View Post
    FAM
    I give you an advice. Firstly check the vent float, it is working or not. If it is not working and your problem is not solved then you can replaced it. You can easily purchase the vent float from local stores and online store. For this purpose you take help of experienced person that have a good knowledge of vent float. It is most important part of sprinkler.
    DIY Junior Member cn90's Avatar
    Jan 2009
    Nebraska
    For those reading this thread, just Google "800M4QT repair kit".
    And look for "Vent Float Kit" that usually includes: "float vent disc assembly (vent float, seal & spring) and bonnet O-ring".
    The Vent Float Kit is usually on sales for about $10.
    Examples are:
    ---> 1/2 & 3/4" BFP: Watts 0887709
    ---> 1" BFP: Watts 0887710
  1. Watts Backflow Preventer leaking from vent
    By linty in forum Boiler Forum
    Last Post: 06-30-2011, 08:35 PM
  2. WTB: vertical float with about 10" travel OR double float
    By ct-esq in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-13-2010, 04:36 AM
  3. Watts 800M4QT blowout fitting
    By bunkers in forum Irrigation / Sprinkler Forum
    Last Post: 10-20-2009, 06:39 AM
  4. Watts outdoor hose bib leaking
    By Dutchman in forum Irrigation / Sprinkler Forum
    Last Post: 07-18-2008, 08:40 AM
  5. Watts Series 800M4QT Anti-Siphon Pressure Vacuum Breaker Cap Leaking
    By rbsfam in forum Irrigation / Sprinkler Forum
    Last Post: 05-18-2006, 10:17 AM
