Results 1 to 6 of 6
Thread: Water pressure Problem
    DIY Junior Member Jsiceloffj's Avatar
    Mar 2011
    North Carolina
    Default Water pressure Problem
    I have a 3/4 in incoming line from a municipal supply with a pressure regulator set at 60 PSI. During the day, the pressure varies from 60 PSI to 100 PSI. This is measured on a gauge after the regulator. It returns to 60 PSI after a time, only to return to 100 PSI later. The regulator has a range of 25 to 75 PSI. I do not have an expansion tank. Is that a solution?
    Obviously this is causing many problems with my plumbing. Any ideas?
    Jan 2008
    If you have a regulator, you must also have an expansion tank. If you have a working expansion tank, then your regulator is not working.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    Sounds like you need to replace the regulator, this is more common with hard water than soft.
    As a band aid you may try cycling the regulator, adjust it all the way down and then all the way up several times to try and break free any gunk in the valve before setting the pressure
    Michael
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by SacCity View Post
    Sounds like you need to replace the regulator...
    In the absense of the required expansion tank, I would not draw that conclusion.
    Hot water usage without an expansion tank will do that. Do a quick experiment. When the pressure is high, open a cold faucet. Verify the pressure drops to your regulator setting (60psi). Then, don't use any water, hot or cold for awhile. My guess is that the pressure will stay fairly constant. If it doesn't, the regulator is probably bad. Then, run a bunch of hot water, then don't use any...watch the pressure gauge...if it rises as the water is heated, you've verified expansion as the problem, and that's exactly what an expansion tank is designed to take care of. The more hot water you use, the more cold has to be heated, the more expansion, and the higher the pressure will go.
    Mar 2011
    North Carolina
    Thanks alot. Joe
  1. Water Pressure Problem/Well
    By guilke in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-28-2009, 08:20 PM
  2. Water Pressure problem
    By Satman858 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-08-2007, 07:07 AM
  3. Water Pressure Problem
    By Alex47 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2007, 07:59 PM
  4. Water pressure problem
    By rebar in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-25-2006, 12:25 PM
  5. Water pressure problem...
    By gameboy in forum Shower & bathtub Forum & Blog
    Last Post: 09-14-2005, 05:31 AM
