Results 1 to 4 of 4
Thread: water coil replacement in Smith Series 8
    DIY Junior Member karpat's Avatar
    Mar 2011
    Massachusetts
    Default water coil replacement in Smith Series 8
    Does anyone know what a fair price is for replacing the hot water coil in my Series 8 Smith boiler?
    Nov 2010
    Maine
    Probably run around 750 or so. coils are expensive. Far better off to get an indirect. Unlimited hot water and a big reduction in your oil or gas bill.
    Mar 2011
    Massachusetts
    Default coil replacement
    Tom I was quoted $2500 for materials and labor for a stand alone hot water heater, that seems like a lot of money what do you think. Plus now I have another piece of equipment that is going to need repairs. I would have to run it by electric seeing gas is not and option. That means running a new outlet, having a higher electric bill by how much I don't know. How many years before it turn profitable?
    Patrick
    An indirect uses the boiler as the heat source and it usually treated as a separate zone. The indirects are generally very low maintenance...maybe replace the circulator, but that could take many many years before it wears out.
  1. Anode rod replacement on AO Smith Heater
    By ktvaughan in forum Water Heater Forum, Tanks
    Last Post: 09-25-2010, 08:26 PM
  2. Replacement Anode for AO Smith
    By Kevin in Michigan in forum Water Heater Forum, Tanks
    Last Post: 06-01-2010, 04:21 PM
  3. Replacement Delta 600 Series Valve
    By kissmine in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2010, 06:46 AM
  4. A.O. Smith water heater
    By aaabbb in forum Water Heater Forum, Tanks
    Last Post: 01-23-2010, 06:40 PM
  5. A.O. Smith Water heater noise
    By Bob the Builder in forum Plumbing Forum Discussion & Blog
    Last Post: 08-20-2008, 07:20 AM
