Results 1 to 2 of 2
Thread: Wrong Fleck 2510 Valve?
    JMann JSM8786's Avatar
    Oct 2010
    Summerfield, NC
    Default Wrong Fleck 2510 Valve?
    I am in the process of converting my upflow acid neutralizer to a down flow acid neutrailzer. I purchased a Fleck 2510 12 Day Valve. Once I pulled it out of the box, I noticed a brine valve connection in addition to the drain valve. Have I made a mistake and ordered the wrong valve? If so, can I convert the valve or do I try exchange it for the correct valve?
    Regenerated type filters use the brine valve to draw regenerant but an AN filter does not regenerate, it backwashes only, so send the valve back to be replaced by a non regenerate type rather than you changing the parts needed for the conversion. You also need the correct DLFC button for your size AN filter so have the dealer set the valve up for your specific use.
  1. Fleck 2510 Salt Dose
    By qpm in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-11-2011, 06:16 AM
  2. Fleck 5600 vs. 2510, Econominder vs. SXT
    By borisgoodenough in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-14-2011, 12:14 PM
  3. Question about removing valve (Fleck 2510)
    By chargedmr2 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-29-2010, 06:53 PM
  4. fleck 5600 valve
    By mywater in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-26-2009, 09:41 AM
  5. Fleck 5600 What goes wrong with age? Why is the large knob hard to turn?
    By adenwork2 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-27-2009, 09:27 AM
