Results 1 to 10 of 10
Thread: 30kgrain softener with Clack WS1 valve losing media out the drain
    DIY Junior Member oreo's Avatar
    Mar 2011
    Georgetown, Ontario
    Default 30kgrain softener with Clack WS1 valve losing media out the drain
    So recently, my 2yr old water softener, has been running out of soft water regularly. Checking things over, I found that there were some softener beads where the softener drain line exits. I then pulled the softener apart, and found the tank was about 1/2 full of beads. The tank is a 8"Dx47". The softener seems to cycle properly and does produce soft water. Looking further, I notice that the WS1, has a white injector(V3010-1E) installed and a 2.7gal/min drain line restrictor.
    From the Clack WS1 manual, it looks like Clack suggests this injector is for 10" tanks. Not sure if the drain line restrictor is also recommended for 10"tanks or not.
    Is it likely that this problem has been caused an incorrectly sized injector and restrictor, or do I need to look further?
    thanks
    Greg
    Feb 2011
    NW Ontario, Canada
    How high is your water pressure? Are you seeing any air spitting at your fixtures? Too much pressure or air behind water can wash beads out of the tank.
    Does your manual say how full the tank should be with beads? Some makers will use the same size tank across a few models and just put in less beads.
    Dec 2009
    Alaska
    8x47?
    can not say that I have heard of that size, 8x44, 9x48, and 10x44 or 10x47.................. but not an 8x47.....
    Did you put this together or did it already come put together from day one?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Your DLFC (drain line flow control) is too big. The size of the media tank dictates the size of the DLFC. For an 8" tank it should be about 1.5 gpm.
    Dec 2009
    Alaska
    Is there a turbulator with this unit?
    Mar 2011
    Georgetown, Ontario
    I presume the water pressure is ok, as it is a municipal system. No air spitting from the fixtures.
    Considering this tank is only 1.37cf, and there is supposed to be 1cf of media, I would expect it to be quite full, however the manual does not say anything about how full the tank should be.
    The tank/valve assembly came assembled, and is a GE #3025653. Says 8x47" right on it, and is sold by these guys.
    http://www.goodwaterwarehouse.com/cat/2_pspv.shtml
    Cool, I was hoping it was a minor issue. Thanks for the responses
    Mar 2011
    Georgetown, Ontario
    There is no tubulator on this unit either.
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by oreo View Post
    There is no way this tank could hold 1 cf of media and have the proper free board. A 8X47 tank only holds .83 cf of media.
    DIY Member JKERN's Avatar
    Jan 2011
    Artesia NM
    Having purchased from them before more than likely someone that assembled your valve just didn't pay attention, thats also why we quit purchasing equipment from them. You have a 3/4 cu3 softner and you just need to change your dlfc.
    Mar 2011
    Georgetown, Ontario
    There is no way this tank could hold 1 cf of media and have the proper free board. A 8X47 tank only holds .83 cf of media......... You have a 3/4 cu3 softner and you just need to change your dlfc.
    I was wondering about that. Pretty much all the 30k grain softeners I've seen, come with a 9x47tank.
    I'm thinking of upgrading the tank to a 10" one, rather than change the dlfc. I found another Clack document, that recommends the white injector, and 2.7dlfc for the 10" tank. I have over 1cf of media from my old softener (the valve assembly kept going on it), so the only cost would be the tank (~$70). This would allow me to run a lower salt dose than I am currently running, pick up some salt efficiency as well as getting a bit more capacity. (In retrospect, I should have gotten a larger replacement than I did. I didn't understand at that time, that in order for the 30kgrain softener to yield ~30kgrains, you need to whack it with a large salt dose).
    Thank you for your comments..
  1. Clack water softener.
    By abcrobots in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-06-2011, 09:21 AM
  2. Softener Tank Media Quanity
    By Earnie in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-08-2009, 06:26 PM
  3. Softener Media Tank Disaster
    By Mike Swearingen in forum Plumbing Forum Discussion & Blog
    Last Post: 10-24-2007, 04:25 PM
  4. Clack softener heads
    By mattbee24 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-14-2007, 10:09 AM
  5. Water softener media and resin
    By Alexdc99 in forum Plumbing Forum Discussion & Blog
    Last Post: 05-11-2006, 09:13 PM
