Results 1 to 2 of 2
Thread: Chlorine pump advise for water treatment needed.
    DIY Junior Member dhp78's Avatar
    Mar 2011
    NY
    Default Chlorine pump advise for water treatment needed.
    Hi.
    I have a stenner pump that stopped working. Something is seized but I am not sure what it is. I think it is in the flow rate controller but I can't get it off. I can turn it to release it but it is stuck on the shaft. I tried pry bars and mallets and can budge it. The pump head was really stuck too, but I got that off. At one point I had a crack in my supply line which sprayed bleach all over everything so that might have contributed.
    Questions:
    1. Is there any way to get this apart so I can check for damage and repair?
    2. The parts seem very expensive even if it can be repaired. Is it even worth messing with or should I just get a new pump?
    3. Is the stenner the best solution or would I be better off with another pump type/brand?
    dhp
    Nov 2010
    Maine
    I think I would just replace the whole pump. Stenner is good.
  1. Pool Chlorine Tablet vs. Chlorine Pellets
    By accord91 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-21-2010, 07:34 AM
  2. Need pump system advise
    By Fixroy1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2010, 07:37 AM
  3. Advise needed in-out shower vlave
    By glenm in forum Shower & bathtub Forum & Blog
    Last Post: 09-05-2009, 06:34 PM
  4. advise on pump that is blowing fuse
    By bjkuhlma in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-12-2008, 12:06 PM
  5. Chlorine water treatment system
    By Alexdc99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-28-2006, 02:48 PM
