Results 1 to 9 of 9
Thread: Dryer is out
    Default Dryer is out
    Ah, Murphy's law. The extended warranty I paid for expired in Dec, today, 5 minutes after throwing in a load of wet clothes the dryer made a clong noise louder enough to scare the cat. It shut off, and smelled like something was burning. I shut if off totally, unplugged it, and didn't like how hot the outside felt. I stupidly, opened the door not thinking, I could had had a real bad hair day, but thankfully, it was just scalding heat coming out and not flames.
    What happened? A belt? ?
    Dec 2009
    northfork, california
    Probably, and then the heat sensor took a bit to shut down.
    Hang the clothes outside facing west, a good hot cloud of gas is incoming. But do not wear them for about 68,000 years after they dry.
    That's funny. They are hanging in my diningroom probably staining my wooden chairs. I just went out and had Sushi with my brother, I was hoping he would come inside to look at it, but he had to get to lay down for work later tonite. Tomorrow, I will pull it apart and see, if I can find anything. I don't know much about dryers other than I know I need one.
    Dec 2007
    What's the brand & model # Cookie?
    I'll look it up for you...
    Dryers are easy....
    Washers? Not So!
    Red, it is a GE, I have to go look for the model.
    Okay, here go,
    MOD DVLR223EE1WW
    SER ZH807560A
    Dec 2007
    Here is all your parts and diagrams....
    http://www.appliancepartspros.com/pa...2624#d23082624
    Usually a couple of spring clips hold on a major panel like the top or front and you just push in on the clips and you are in.
    The belt is only $10.82
    I am going to pull it apart tomorrow before work, thank you Red for all the work in finding it.
    Dec 2009
    What did you find inside?
    Thank you all, the dryer is now fixed. It was just a belt.
  1. Dryer Duct
    By chefwong in forum Remodel Forum & Blog
    Last Post: 05-19-2010, 12:19 PM
  2. Gas Dryer Won't Get Hot
    By Kiko in forum Remodel Forum & Blog
    Last Post: 03-09-2010, 11:15 AM
  3. Gas Dryer
    By Southpaw134 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-09-2009, 06:47 AM
  4. Dryer Vent
    By Still_Waters_43 in forum HVAC Heating & Cooling
    Last Post: 09-18-2009, 08:28 PM
  5. dryer vent
    By Master Brian in forum Remodel Forum & Blog
    Last Post: 04-26-2009, 06:41 PM
