Thread: Curious about Options?
    DIY Junior Member apiratelooksat40's Avatar
    Mar 2011
    Seacoast NH
    Default Curious about Options?
    Hello all,
    Firstly, let me say I'm so happy to have found this forum. I've been reading and searching for the past couple of days and am thrilled to have come across a resource like this.
    I'm looking for some water options for a piece of land my brother and I have in Northern NH where we plan to build camps. The property has a producing spring in gravely, shaley ground. Our first thought was to dredge out where the spring is reaching the surface (something the previous property owners began), install a cistern to collect the water and keep out surface contamination, and using a ram-pump, pump the water to the cabin sites. However, the more I'm reading about the installation of a driven/stand point well, the more I'm thinking this could be an option. The camp sites are located several hundred feet (and a rise of about 30') from the spring itself. The flow rate is better than 10gpm in the Spring and early Summer, but drops off to 2-4gpm in the dry season (keeping in-mind that this is basically undeveloped.). My thoughts are that with the knowledge there's a working spring there, and the hopes that the Ground up by the building sites is the same as the spring site, a stand point with a pitcher pump would be the way to go.
    Any thoughts would be appreciated.
    Nov 2010
    Maine
    You have to find out if you can mess with the spring first. Some towns yes and some no. A point would probably be a better choice.
    In the trades WellWaterProducts's Avatar
    Feb 2011
    Northwood NH
    I've never seen a ram pump used in NH
    Chris Kofer
    h2oguy.com
    Mar 2011
    Seacoast NH
    Saw one working over in the Weare area...pretty slick, if you have the flow-rate and can get enough drop to your headpipe.
  1. Replies: 1
    Last Post: 02-23-2011, 02:30 PM
  2. curious about a septic no-no///
    By rbico in forum Plumbing Forum Discussion & Blog
    Last Post: 06-03-2010, 07:11 AM
  3. Just curious
    By krow in forum Terry's Corner
    Last Post: 02-11-2008, 06:05 PM
  4. Just Curious...
    By dwells in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-22-2007, 08:10 AM
  5. Curious about sound...
    By jrseaberg in forum Plumbing Forum Discussion & Blog
    Last Post: 03-20-2007, 07:30 AM
