Results 1 to 2 of 2
Thread: Takagi TK3 No hot water
    DIY Junior Member tpsmak's Avatar
    Mar 2013
    California
    Default Takagi TK3 No hot water
    Alright.. I need some help. My TK3 just stopped making hot water. Here are some facts about what is going on...
    #1-No blinking LED unless the hot water is turned on at the faucet.. then it just blinks once every few seconds.. nothing continuous.
    #2-Fan blows when hot water is turned on at the faucet.
    #3-The unit was working fine this morning after I descaled it yesterday. We have done 2 loads of laundry and my wife took a shower this morning and it was all fine till now
    #4-Initially I found a lose wire that may have caused the fan to not blow. After I wiggled it a bit the fan now works..
    Does any one have any suggestions?
    Mike
    In the trades Dana's Avatar
    Jan 2009
    Buy the remote control unit (~$100 order of magnitude) and install it- it'll spit a code (interpretations found on page 26 in the manual) of the sensed error that caused it to shut down. One blink means it either couldn't read the dipswitch setting or there is something wrong with the computer board (or it's connections.) I'm not sure how susceptible the TK3 is to power surges (probably fairly robust), but induced voltage spikes from lighting strikes or extreme switching noise on power lines can do-in just about anything.
    Takagi's technical help line is fairly DIY-friendly and will talk homeowners through the diagnostics without an hourly charge: 888.882.5244
  1. Takagi T4 starts with cold water use
    By mlnk in forum Tankless Water Heater Forum
    Last Post: 12-26-2011, 02:07 AM
  2. Takagi TK2 looses inline water pressure
    By Sab in forum Water Heater Forum, Tanks
    Last Post: 10-11-2011, 03:13 PM
  3. Water Going Cold with Takagi Tankless
    By monty in forum Tankless Water Heater Forum
    Last Post: 05-28-2010, 11:09 AM
  4. Problem with Takagi & Radiant Heat &Domestic Hot Water
    By siammurph in forum Tankless Water Heater Forum
    Last Post: 09-29-2009, 01:29 PM
  5. Problem with Takagi & Radiant Heat &Domestic Hot Water
    By siammurph in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2008, 12:24 PM
