Results 1 to 3 of 3
Thread: changing cast iron flange
    Default changing cast iron flange
    My toilet was wobbley so i removed it and i have a cast iron flange connected to a cast iron pipe. the flange was broken on one side and i broke the other side trying to get it lose. How can i remove it. I tried using the repair flange kit but they wouldn't tighten straight and the toilet still moved. any advice.
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    Default flange
    Whack the flange with a hammer. It will crack and you will be able to pry it off. Save the lead ring that is inside the flange right now.
    You need a couple strands of oakum and means to pack the oakum and melt and pour that molten lead. Then you need a tool to pack the lead in tight.
    If you decide to go that route, come back and ask, because you will get several good answers.
    Yakima WA
    Working with cast iron pipe, oakum, and molten lead is not really a job for a DIYer. You should hire a professional for this one.
