Results 1 to 7 of 7
Thread: Dryer feed, how far is too far?
    DIY Junior Member acrscout's Avatar
    Mar 2011
    Northern Virginia
    Question Dryer feed, how far is too far?
    Hello,
    I am considering moving my laundry from the basement to the living level. (Gotta keep the wife happy).
    I have two questions
    1) How far is too far to run 10/3 cable? It looks like I will need about 70' to get from the box to the new dryer point.
    2) If the distance is not too far, do I have to drill every floor joist or can I nail up so 1x4 and surface mount the cable?
    Thank you,
    Fred
    First, what size circuit breaker does the dryer require? That, along with the length, will determine what size wire gauge is required. 10g may be too small.
    Mar 2011
    Northern Virginia
    30 Amps 220 v
    Mar 2011
    Northern Virginia
    30 Amps 220 v
    Jun 2007
    North Carolina
    nail the 1 by then install the 10/3 on top (or bottom depneding on you outlook)
    Electrical Contractor Bobelectric's Avatar
    Feb 2009
    Eighty Four,Pa. 15330
    Drill It!.......
    DIY Member teamo's Avatar
    Jun 2005
    Massachusetts
    Use the #10 copper and a 30 amp breaker and you should be fine.
  1. gravity feed spring
    By Ridgeview Farm in forum Solar and Geothermal Water Heating Forum
    Last Post: 10-03-2011, 02:58 PM
  2. gravity feed calculation help !!!
    By YourFinancialPlanner in forum Irrigation / Sprinkler Forum
    Last Post: 08-15-2010, 11:58 AM
  3. Stove Hood feed....
    By Rich B in forum Electrical Forum discussion & Blog
    Last Post: 04-21-2010, 01:55 PM
  4. Which line to use for water feed?
    By DIYourselfer in forum Plumbing Forum Discussion & Blog
    Last Post: 01-27-2010, 06:57 AM
  5. Want to run new feed to garage
    By arfeller in forum Electrical Forum discussion & Blog
    Last Post: 11-26-2009, 09:44 PM
