Keano, I don't typically give advice here since I'm new at this and still feeling my way through my own plumbing projects. But I just wanted to share with you my experience with CI as a DIYer.
In my case, I had a 4" CI vent to tap in to in order to install a Wye for a second toilet vent. The location of choice was in a closed wall, behind the toilet. Naturally, I had to remove the toilet and open the wall the gain access to the pipe, but it sounds like you're at that stage already.
Then, with nothing but a 4" angle grinder, I began cutting away at the pipe. The grinder easily got half way through at my cut marks, then I had to back out and slice a wedge out of the section I was removing. A couple of vertical cuts along the sides, and the front half of the piece I was removing practically fell out. This left me a big opening to get at the back half, which came out just as easily. The cuts were clean and smooth and straight. I slapped the no-hub fittings on there, slid the metal bands out of the way, rolled up the rubber coupling, and the wye slid right into place.
It was intimidating to start, but actually a very straight forward and satisfying project. Only two words of caution:
- Griding iron is extremely messy. Wear a mask. Wear goggles. Protect finished surfaces with plastic.
- Iron pipe is heavy. Make sure what you're cutting is supported -- both ends, before you get to cutting. Riser clamps for iron pipe are cheap, and will prevent an unsupported pipe from dropping through the floor or pulling through the roof.
http://www.terrylove.com/forums/show...-CI&highlight=
