Results 1 to 4 of 4
Thread: Replacing lines on hwt
Hybrid View
    DIY Junior Member billyh's Avatar
    Feb 2011
    Ontario
    Default Replacing lines on hwt
    I am 99% sure of this but just in case there is a way around it...
    Can I replace the lines on a hwt without draining the entire tank?
    I am assuming not because it's under pressure... but thought I would ask anyhow.
    Turn off the water and open some faucets.
    If it's electric, turn off the breaker first.
    You only need to drain the tank below the connections, and if those are on top, not even then.
    It is only under pressure until you turn off the water supply and open a faucet. As long as what you are doing is above the water level in the tank, it will NOT leak water out.
    Feb 2011
    Ontario
    Thank you. I had to replace both the lower line (near ground) and the one on the top. So, I ended up draining it.
    Your answers definitely made this easier! Thank you.
  1. replacing water lines...does this sound right?
    By groovychic in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-06-2007, 06:07 AM
  2. Replacing supply lines
    By citykid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-13-2006, 11:15 AM
  3. Replacing copper lines in slab
    By grummpyman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-22-2005, 05:22 PM
  4. Replacing Cast Iron Sewer Lines In Crawl Space
    By DanMcD in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-27-2005, 07:54 PM
  5. Replacing Cast Iron Drain Lines
    By AndyDavis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2005, 10:12 AM
