Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: GE (Rheem) 40 Gal Gas - Water cools when not used
  1. #16
    DIY Junior Member doc_u's Avatar
    Nov 2008
    SF California
    No, even in the original install (which I was not a part of) there was no reduction in size.
    The new one uses 3/4" CPVC and is 3/4" all the way to the run in the wall (3/4" copper), which I shortened and 90'd out to a 3/4" copper threaded coupling.
    None of the couplings reduce size. I actually used the 3/4" copper pipe I removed from the wall for the various bits and pieces I had to add on the supply side, and for the stub out at the top of the 90 out of the wall.
    Yes, the straps are (barely) in the right areas, but I had a few issues to deal with there.
    Is there any issue with the TPR valve being mostly sideways? I wasn't able to find a reference in the code that was explicit about this, and since they use top-mounted ones all the time, I figured it would work.
    As for the BW, there's really only one place on the net that sells them, a quick google search will confirm.
    I don't really want to post the name here, as they may not be in the good graces of this forum.
    -Doc
  2. #17
    BW makes a neat tempering valve setup that is easy for a DIY'er. This would allow you to set the desired outlet temp, while keeping the tank's temp higher (which makes it look bigger - handy when you have guests and lots of people taking showers). Not sure it is compatible with that model, but take a look http://bradfordwhite.com/products/re...ce_package.asp
  1. Rheem water heaters...wtf?
    By Double0EK in forum Water Heater Forum, Tanks
    Last Post: 06-30-2009, 11:29 AM
  2. Rheem Water Heater has me stumped!
    By lizzydog in forum Water Heater Forum, Tanks
    Last Post: 05-09-2009, 06:59 PM
  3. <<<<Rheem Gas water heater HELP>>>
    By Jayshiv_patel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2008, 07:09 PM
  4. which rheem water heater???
    By popawheelie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2007, 03:06 PM
  5. Rheem 30 Gal. Water Heater
    By Bigmike in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-21-2007, 03:00 PM
