Results 1 to 7 of 7
Thread: Quick Question about No-Hub
    DIY Member glnow's Avatar
    Mar 2007
    CA
    Default Quick Question about No-Hub
    Is it legal to no have no-hub connection on a vertical vent line that is behind a wall?
    I have a metal vent pipe with a hairline crack that needs to be addressed.
    quote; Is it legal to no have no-hub connection on a vertical vent
    The word "no" in the question does not make sense. Of course it is legal to have them in walls, otherwise we could NEVER install a No-Hub waste and vent system. If "no" meant "not" then the question is illogical, if not ridiculous.
    Mar 2007
    CA
    Whoops, many apologies for the confusion caused by the typo in my original post.
    Yes, I was checking to see if it was OK to have the no-hub union behind the finished wall and it sounds like that is allowed.
    Do I need to add some additional bracing to support the vent pipe when I cut into it, so that the pipe above my cut doesn't come tumbling down? If yes, what do I use?
    The obvious answer to that is YES. I am assuming the vent is cast iron, and you do have to clamp it very, very well. Cast iron is very heavy and a flimsy half-a**ed attempt won't cut it. The vent is likely only supported by itself, so when you cut it, it loses that support and will come down fast and hard.
    Mar 2007
    CA
    Understood. What type of clamping/strapping system should be used here?
    Sorry, I should say that I'm not going to do myself, it's beyond me and I'll be going with a pro.
    But this info will help me be sure it's being done correctly.
    Nov 2010
    Maine
    The best thing would be a riser clamp but I don't think the big box stores carry them.
    How the vent pipe is installed ABOVE the cut determines whether it is already supported or not. Only someone on site can make that determination, but I have cut very few cast iron lines which were NOT already supported by the piping configuration above the cut.
  1. Quick question on glass framed pivoting shower door hardware question
    By watson524 in forum Shower & bathtub Forum & Blog
    Last Post: 02-09-2011, 05:38 PM
  2. Quick Question
    By akantler in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2010, 08:35 PM
  3. Quick code question - IPC
    By nukeman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2010, 01:40 PM
  4. Just a quick question?
    By justawop in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2009, 04:26 AM
  5. Quick Toto Question
    By kahcrt in forum Toilet Forum discussions
    Last Post: 10-26-2007, 06:50 AM
