Results 1 to 4 of 4
Thread: Franklin Electric control box making chattering noie
    DIY Junior Member mnkcon's Avatar
    Mar 2011
    Rhode Island
    Default Franklin Electric control box making chattering noie
    Hi
    as it is 9pm and too late to call a professional, i need to know what i should do about the control box making a chattering noise
    I shut the breaker off until i can get a diagnosis
    i had just finished doing dishes then started the washing machine - halfway through the fill of the washing machine tub the control box started making a chattering noise at about 5-10 min intervals
    any ideas? feedback appreciated
    In the trades WellWaterProducts's Avatar
    Feb 2011
    Northwood NH
    If you're lucky it's just a failing control box. I think you can guess the unlucky outcome.
    Chris Kofer
    h2oguy.com
    Mar 2011
    Rhode Island
    thanks - i think
    the pump is only about 7 years old - will i kill it if i turn the power back on to the control box
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    You sure it's not the pressure switch chattering? There are no mechanical links in MOST C-Boxes to chatter but I have heard some buzz and pop on occassion. Also there is a relay in the box that might make a click but not sure how loud it would be...
    I suspect your tank is waterlogged and is either causing of amplifying the problem.
  1. Electric heater control
    By 801Sparks in forum Electrical Forum discussion & Blog
    Last Post: 01-03-2011, 01:02 PM
  2. Franklin 3 HP Deluxe Control Box parts
    By andybull in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-26-2010, 10:04 AM
  3. Parts for Franklin Control Boxes
    By Rutherfordman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-18-2009, 05:08 AM
  4. Replacing Control Box, Franklin
    By Leaky Boot in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-09-2008, 07:16 AM
  5. Well pump chattering
    By steve b. in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-09-2006, 07:41 AM
