Results 1 to 5 of 5
Thread: Water Softener On = No Pressure, Bypass = Normal Pressure?
    DIY Junior Member jsarin1's Avatar
    Sep 2010
    Naperville, IL
    Default Water Softener On = No Pressure, Bypass = Normal Pressure?
    I just replaced the media in my water softener with a standard resin and amount as suggested by the supplier. After reinstalling the softener I am getting no pressure at all to my house. When I bypass the the softener, I get normal pressure.
    I have manually regenerated twice without any change. Any ideas of why this is happening?
    I removed the turbulator and cleaned it thoroughly before re-installing.
    Feb 2011
    NW Ontario, Canada
    Does the softener have a top basket? If so, have you checked to see if resin beads were carried up into it? If there is no top basket, maybe resin beads got carried up into the valves in the head. I had that happen on my iron filter except it was pumicite, not resin beads. Can you see where the backwash discharges to see if there was any resin beads flushed out?
    Dec 2009
    Alaska
    What kind of system and what kind of valve do you have on the softener?
    Did you plug the turbo before filling the media tank with the resin?
    Sep 2010
    Naperville, IL
    The turbulator was plugged before I refilled the resin.
    It is an Autotrol 155 unit.
    I unplugged the softener and noticed that in the output port that goes to the house (not from the well) had some resin beads in it. Does this mean that some of the beads are in the valves? If so, how can this be repaired?
    For an update, I am only getting drips of water to all of my water fixtures not bypassed. When bypassed I still have normal flow.
    Dec 2009
    Alaska
    How did you refill the system with water after the new resin was in and the valve was back on?
    If you found resin in the valve sounds like a large enough air pocket had enough resin to plug up the valve body when the system was in the back wash.
    About the only way for an autorol valve to be cleaned would be a full break down and flushing.
  1. What is considered normal water pressure into a house?
    By w1ljm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-16-2014, 06:36 AM
  2. Well water pressure normal than drops suddenly
    By psdowns in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-17-2010, 07:55 AM
  3. Water pressure high then tapers off to less than normal.
    By cjs45lj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2010, 07:07 AM
  4. high dynamic water pressure - what is normal?
    By rrr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-23-2007, 09:02 AM
  5. water pressure drops when changing zones and wont come back up to normal
    By laborer90 in forum Irrigation / Sprinkler Forum
    Last Post: 07-01-2007, 06:19 PM
