Results 1 to 2 of 2
Thread: pressure testing well casing
    DIY Junior Member cabincrazy's Avatar
    Feb 2011
    Minnesota
    Default pressure testing well casing
    i have a 2" sandpoint about 50 ' deep is it possible to pressure check the 2" casing with air pressure to check for leaks or will it just push the water back out through the sandpoint theres about 15 to 20' of static water in the well
    Well driller,pump repair. and septic installer Waterwelldude's Avatar
    Feb 2009
    Texas
    If you tried that, you would push the water back out to a point.
    When the air pressure reached the same pressure as the water coming in it would just stop, the pressure would not go up or down.
    Now that would also depend on the how good the grouted seal is between the earth and the casing. If there is a small leak there, the air and/or water would seep out beside the casing and out the top of the bore hole.
    "I shall never surrender or retreat" -Col. William Travis
  1. Pressure Testing Gas Line
    By cloves in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2010, 08:33 PM
  2. Pressure testing DWV
    By jar546 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-22-2008, 04:04 PM
  3. Testing for air pressure in a house.
    By Mikebarone in forum HVAC Heating & Cooling
    Last Post: 05-19-2008, 09:16 PM
  4. What pressure for air testing copper?
    By seaneys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-12-2008, 08:24 PM
  5. Pressure testing lines
    By Jeremy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2005, 06:05 PM
