Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Stove Wire Repair
  1. #16
    DIY Senior Member Kiko's Avatar
    Jul 2009
    Royal Oak, Michigan
    If you did NOT get a good crimp, you will eventually know about it when the added restistance causes the connection to burn out again.
    The connections only shorted out after the house cleaner pulled on the wires when cleaning the stove. I pulled hard on these crimps, and they seemed very solid. I'm not sure what you mean by "added resistance" ???
  2. #17
    If the connection gets loose, it will act like a resistor, heat up like the heating element. The connector metal has some spring to it. Once heated and cooled depending on how good the connection is, it can lose its temper or springiness, and when it expands, not contract again so it no longer makes a good connection. That's why the crimper tool is more science than art...hard to determine if you got a proper crimp. Often, it really doesn't matter much. But, on high current and things like heating elements when exposed to extremes in temp, it can make a big difference. Time will tell. The proper crimping tool takes this all into account, and uses the best shape and compression to form a reliable, long-lasting, low resistance connection. SOmetimes, this is overkill; sometimes, it is essential.
  3. #18
    Dec 2009
    northfork, california
    Which is why its a very good practice to re-torque large breakers with aluminum cables in them sometime after installation.
  1. New 220 4 wire stove and old 220 three wire plug
    By Wardsweb in forum Electrical Forum discussion & Blog
    Last Post: 01-04-2010, 05:44 AM
  2. 4 Wire Cable in a 3 Wire Connector Setup
    By chefwong in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2009, 03:17 PM
  3. How to change from 2 wire to 4 wire furnace
    By snuffy47 in forum HVAC Heating & Cooling
    Last Post: 06-04-2009, 05:09 PM
  4. 1 pole, 2 wire or 2 pole 3 wire switch for water heater?
    By bigtime in forum Electrical Forum discussion & Blog
    Last Post: 11-04-2007, 05:13 PM
  5. 2 wire vs 3 wire thermostat
    By d_butka in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-03-2005, 07:48 PM
