Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Stove Wire Repair
    DIY Senior Member Kiko's Avatar
    Jul 2009
    Royal Oak, Michigan
    Default Stove Wire Repair
    One of the wires to a stove burner shorted out (I think the cleaning lady had pulled on it ). Now, I need to cut off several inches of burned out wire and add a few inches of new wire so it will be long enough to reach the ceramic connector at the burner.
    The wire says 150 C, but I can't make out the AWG. Does anyone know the correct replacement wire for this, and if I can just use a high temp wire nut to complete the repair?
    Jun 2007
    North Carolina
    Instead of repairing the conductor why not replace the entire length using a Type Z or TFE conductor?
    Jul 2009
    Royal Oak, Michigan
    My other option is to replace the entire wire harness, which I would prefer to avoid, since I only need about 4" of wire replaced.
    My main concern is finding the correct gauge wire. I called two place that sell high temp conductors by the foot, but they are both 14 gauge. That just doesn't seem right for a stove burner??
    14 ga. wire will handle 15 amps. That is 3600 watts, 240, and the burners are not that big.
    Jun 2007
    North Carolina
    If you insist on patching the wire please use a ceramic wire nut
    Jul 2009
    Royal Oak, Michigan
    I've already bought the ceramic wire nut.
    Second question: is there a place on my Croc's wire stripper to crimp on a high temp crimp terminal? Can a pliers work? Or do I need to buy a special crimper?
    Jun 2007
    North Carolina
    Quote Originally Posted by Kiko View Post
    why not just buy a ceramic twist on wire nut?
    The use of a pressure connector you take a chance of damaging the insulation and you will be right back to where you are now
    Jul 2009
    Royal Oak, Michigan
    The ceramic wire nut is to connect one end to the existing conductor. The crimp-on terminal is what is needed to connect the other end to the burner. A screw passes through the eye of the terminal, and holds it in place. So, will I need a special crimping tool, or will my Croc's work for this?
    Jun 2007
    North Carolina
    Yes I am stupid and this proves it.
    Squeeze her down
    Because of the heat, there is more expansion/contraction of the connectors and it becomes somewhat critical to ensure you get a good crimp. If it isn't tight enough or properly indented, it can loosen, change the resistance, and fail again. There are calibrated crimping tools that won't release until you've completed the proper compression. They have fingers or shaping dies designed for the specific connector, wire size, and application. You may not have trouble, but it is a potential weak point if it is not done well.
    Jul 2009
    Royal Oak, Michigan
    Turned out, I didn't need to splice in any new wire. I just crimped on new terminals (I ended up replacing four terminals) using a vice grips and got a nice crimp.
    Thanks to all who responded.
    If you did NOT get a good crimp, you will eventually know about it when the added restistance causes the connection to burn out again.
    Jun 2007
    North Carolina
    message deleted, I told you this type of post would not be allowed
    See the highlighted part in the quote above
    Dec 2009
    northfork, california
    How do you crimp anything with vice grips? May as well use a hammer.
    Jul 2009
    Royal Oak, Michigan
    Quote Originally Posted by ballvalve View Post
    I thought it was strange too, but the owner of the hardware store where I bought the terminals suggested it, and the connections seemed very good.
  1. New 220 4 wire stove and old 220 three wire plug
    By Wardsweb in forum Electrical Forum discussion & Blog
    Last Post: 01-04-2010, 05:44 AM
  2. 4 Wire Cable in a 3 Wire Connector Setup
    By chefwong in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2009, 03:17 PM
  3. How to change from 2 wire to 4 wire furnace
    By snuffy47 in forum HVAC Heating & Cooling
    Last Post: 06-04-2009, 05:09 PM
  4. 1 pole, 2 wire or 2 pole 3 wire switch for water heater?
    By bigtime in forum Electrical Forum discussion & Blog
    Last Post: 11-04-2007, 05:13 PM
  5. 2 wire vs 3 wire thermostat
    By d_butka in forum Plumbing Forum Discussion & Blog
    Last Post: 02-03-2005, 07:48 PM
