Results 1 to 5 of 5
Thread: Two 6A devices on a 15A circuit (?)
    Nov 2005
    Default Two 6A devices on a 15A circuit (?)
    Can I hear whether this is definitely unwise, or if it's acceptable:
    Two 6A devices on a 15A circuit.
    Neither require a dedicated circuit.
    The circuit is below the kitchen countertop.
    Yakima WA
    If 6 + 6 still = 12, and as long as the devices will not exceed 15 amps total, you're good to go.
    Feb 2011
    NW Ontario, Canada
    We generally tend to follow the 80% rule for single fed devices. However, many of the equipment I deploy have load balancing power supplies fed by two or three circuits so if one circuit were to fail the other one or two need to be able to pick up the slack so I have to base it on worst case possibility.
    http://ecmweb.com/mag/electric_sizing_circuit_breaker/
    Yakima WA
    80% of 15 = 12. I still say the would be no problem.
    Plumber jimbo's Avatar
    I we cannot put two 6 amp loads on a 15 amp circuit, we will have to re-write the building codes and completely rethink how we live!!!!!
  1. Convert 220 circuit to 110 circuit to be run to new subpanel
    By C Willard in forum Electrical Forum discussion & Blog
    Last Post: 10-24-2009, 06:39 PM
  2. Replacing recessed thermal overload devices
    By thebeave in forum Electrical Forum discussion & Blog
    Last Post: 01-07-2009, 07:43 PM
  3. I need to pull a new circuit for a hot tub.
    By Erico in forum Electrical Forum discussion & Blog
    Last Post: 11-18-2007, 04:06 PM
  4. NRTL requirements for user devices ???
    By mistrhat in forum Electrical Forum discussion & Blog
    Last Post: 09-21-2007, 08:06 AM
  5. Are there devices where you can set a temp for shower
    By herbolaryo in forum Shower & bathtub Forum & Blog
    Last Post: 06-07-2007, 02:35 PM
