Results 1 to 10 of 10
Thread: A simple Question
    Retired tool & Die and Mechanic Giles's Avatar
    Aug 2007
    N.W. Alabama--Florence--
    Default A simple Question
    When working with simple 110v cords, such as lamp cord, where there is only two wires, I know that the small spade is the hot.
    Some of these cords have an identifying "rib" molded into the outer covering. I have always thought the "rib" was to identify the "hot", however I have recently found that it is "neutral" on the last few I have dealt with.
    Is there a standard rule?
    I told you it was a simple question
    Feb 2011
    NW Ontario, Canada
    I would never trust any cord manufacturer to follow a rule even if one existed. I always verify by putting a meter on it and I verify wall jacks as well.
    That reminds me... I need to buy another outlet tester... mine grew legs again.
    http://www.google.com/search?q=outlet+tester
    Plumber jimbo's Avatar
    The "identified conductor" is always the NEUTRAL.
    Aug 2007
    I always do the same--even when I turnoff breaker I always check.
    DIY Junior Member ianrtech's Avatar
    Feb 2011
    Petaluma, CA
    this i have not dealt with lately but it used to be one way the in the 90's they changed it to the other. use your meter does that help
    Many cords are oriented so the neutral wire lines up with the polarized prong, thus you can determine whether the ribbed wire goes to it or not.
    Aug 2007
    That"s what I am thinking--On this same subject, a few years ago, I purchased a "Westinghouse" swag light cord and ,of course, it was Made in Communist China. The hookup instructions stated it didn't matter how the wires were connected. I knew IT DID!! So I eMailed the company and voiced my complaint. They responded with a thank you and said I was absolutely correct and it would be corrected.
    I wonder how many are connected wrong and if the company actually addressed the issue??
    Quote Originally Posted by ianrtech View Post
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Giles View Post
    Ja, I've seen many DIY segments on wiring a lamp cord where they either fail to mention which side of a lamp base the neutral must go to or claim it doesn't matter. I can just imagine someone trying to change a bulb with the neutral switched and the hot wired to the threaded side of the base! I could see some people do it by braille, guiding the bulb into the base with one hand while standing bare-footed on a damp concrete floor.
    There are still a huge amount of older lamps way before polarized plugs were available...then, it truly didn't matter (well, it did, but I doubt anyone used a meter to determine which side was neutral).
    Feb 2011
    NW Ontario, Canada
    When I was a young boy, my parents had a metal clip-on lamp on their metal headboard. I didn't need a meter to determine what side was neutral as I'd get shocks touching the footboard while bare foot on the tiled basement floor. Reversing the plug solved it but isolating the neutral would have been the right thing to do.
  1. Simple question
    By eod4647 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2009, 12:04 PM
  2. Simple Question
    By LocalLoser in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2009, 11:34 PM
  3. Simple P trap question
    By Interlodge in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2009, 08:52 AM
  4. a simple question
    By jwelectric in forum Electrical Forum discussion & Blog
    Last Post: 12-08-2008, 02:21 PM
  5. A simple question
    By rj8214 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-21-2007, 09:13 PM
