Results 1 to 7 of 7
Thread: Power Rating
    DIY Junior Member denverboz's Avatar
    Mar 2011
    Denver, CO
    Default Power Rating
    OK at the risk of sounding like a dummass, I gotta ask what power rating means, as in
    power rating 120V 60 Hz 1281W, which are the specs for a Toto Neorest toilet.
    From what I can gather it doesn't seem to mean it uses 1281W, but I been wrong before.
    However if I am right is there any way to deduce just how much power it does use just from the power rating?
    TIA for any help .
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    It means you need to supply it with a minimum 15 amp circuit.
    Mar 2011
    Denver, CO
    Quote Originally Posted by ActionDave View Post
    so you mean it's own dedicated circuit?
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    I answered in the other post but yes, a dedicated 15 ampere circuit would be the best.
    Jun 2007
    NY State, USA
    Quote Originally Posted by denverboz View Post
    If it says 1281 watts then yes, it certainly does mean it uses, or can use, 1281 watts.
    Why would you think differently?
    No way. Not just from the ratings shown. If it uses a certian amount of power that's that. Unless of course there are settings on the unit that can vary the power, but that still does not change the fact that it CAN draw that much at any given time.
    May I ask why this is an issue?
    Jun 2007
    NY State, USA
    I also agree that a dedicated GFI protected circuit is required.
    That is the maximum it could use...in 'standby' mode, it probably uses much less. To heat the water (and maybe the seat) quickly, it needs to draw some serious power. It probably does this 'on-the-fly', rather than keeping a quantity of water hot all the time. As to the seat, not sure...
  1. EDR Rating for Arco Convectors
    By BKTilePro in forum Boiler Forum
    Last Post: 01-23-2010, 01:42 PM
  2. UL rating for bathroom lights?
    By nv178177 in forum Electrical Forum discussion & Blog
    Last Post: 07-18-2009, 05:57 PM
  3. FAU rating- input vs. output?
    By ked in forum HVAC Heating & Cooling
    Last Post: 08-20-2007, 08:45 AM
  4. How do I apply AIC or Interrupting Rating?
    By Pzlaket in forum Electrical Forum discussion & Blog
    Last Post: 06-22-2007, 04:51 PM
  5. what rating suction line should I use?
    By Byoung5187 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-03-2006, 05:17 PM
