Results 1 to 13 of 13
Thread: Toto Aquia 10" rough - will it work with 10 7/8" CST412MF.10
    DIY Junior Member bronsonb's Avatar
    Dec 2004
    Smyrna, GA
    Default Toto Aquia 10" rough - will it work with 10 7/8" CST412MF.10
    We are updating our shower and adding tile to our bathroom walls. with these changes, we are ending up with a toilet flange that will be 10 7/8 approximately from the finished wall. Obviously, a 12" rough in toilet won't work.
    Is there a problem using a 10" rough in toilet? We like the Toto Aquia (CST412MF.10). Is it a problem if the rough in is slightly over 10"? I guess I am wondering if the toilet tank needs to sit flush with the finished wall or else there will be a problem. Right now, it looks like it'd be 7/8 of an inch from the finished wall.
    Thanks for your help!
    The CST412MF.10 installed on the Queen Anne neighborhood in Seattle.
    Few, if any, toilets set tight against the wall. For example, both of my bathrooms have exactly 12" rough-ins. Of course I have toilets listed as 12" rough-in toilets, but both of them have about 2" between the wall and the tank. You can always put a toilet on a flange that is set greater than the rough-in size listed for a toilet, it's when you want to put a toilet on a rough-in that is less than the toilet's listed size. To my knowledge, toilets from all manufacturers are this way. There is certainly nothing wrong with a 7/8" space behind your toilet.
    Dec 2004
    Smyrna, GA
    Thanks Gary for the prompt reply! I am much relieved. When I pulled up the installation instructions for the Toto, it said "exactly 10" " and didn't mention "at least" :-), so I was a bit worried that perhaps the tank needed to use the wall for support, which would make it an awfully weak tank/base connection if that was required.
    Thanks again!
    Most toilets set out from a wall a bit.
    If you want to go with a standard 12" bowl, the Eco Drakes will work at 10-7/8"
    Dec 2004
    Smyrna, GA
    Thanks for the information Terry. This is good to know, but to be honest, now that we've seen the Aquia, we LOVE the look. The skirted front will be very nice, and my wife is excited about it. We've got one on order, and I also found out that my water provider will give us a $100 rebate after we install it. We're in the process of updating the bath, so it won't be installed for at least a month, but we really can't wait. I've read so many good things about it. Who would ever think I'd be excited about a toilet?!?!?
    And you know that Toto is based in Morrow Georgia, right?
    TOTO USA, INC.
    1155 Southern Road
    Morrow, Georgia 30260
    Dec 2004
    Smyrna, GA
    I must admit that I didn't know that. It's nice to support locally designed (and perhaps made) products! Perhaps it's time to take my cub scouts on a tour of a toilet factory. I'm in Marietta, so I'll have to see how far of a drive it is. Might be a neat deal if they offer factory tours ;-).
    Toto maintains high quality on its porcelain castings by using a different technique verses most others: instead of pouring in the clay, they use a dryer mix. The casting changes size less because there is less moisture, and it is less likely to slump out of shape. All of them are significantly larger before drying and firing than the finished product. So, a little difference in moisture at the beginning can make a big difference in the end product. By controlling that better, they get better consistency between items.
    It looks like you are 36 miles from the factory.
    A lot of the product that I sell is made there. That should be like a 47 minute drive.
    The Toto factory address us 1155 Southern Road which is between Morrow and Jonesboro. Exit I-75 toward Jonesboro. Turn right on Southern Road.
    Dec 2004
    Smyrna, GA
    Sounds like you might have done the tour, Gary! If I can get a weekend tour, that would great. Morrow is catty-corner across metro Atlanta from where I live, so getting there on a weekday afternoon would be difficult. I'm going to se what I can work out though.
    Didn't do a tour of Toto, but we have relatives in the Atlanta area , and on one of our visits, we did the Gone With the Wind tour in Jonesboro, but I actually just used Google Earth to get the directions. lol
    DIY Junior Member juneb's Avatar
    Jan 2014
    ca
    Default 12 in rough in toilets with 10.5" actual rough in
    Hi, Does anyone know any brands/models that would fit flush against the wall with 10.5 rough in? Your remark on most 12"-rough-in toilets toilets having 2" spaces against the wall, leads me to believ most 12" toilets will fit snug in a 10/5 in rough in. I would like to purchase a 12 in-rough-in toilet since there are more styles available at more reasonable prices. Does anyone have the "American Standard Clean White 1.28-GPF/4.85-LPF 12-in Rough-in Watersense Round 2-Piece Comfort Height Toilet" and know if it will fit? thanks in advance!
    http://www.lowes.com/pd_84873-834-25...can&facetInfo=
  1. Aquia, what rough-in do I need?
    By Donn2390 in forum Toilet Forum discussions
    Last Post: 01-17-2009, 10:53 AM
  2. Toto Aquia with Unifit Adapter and 14" rough-in
    By pankaek in forum Toilet Forum discussions
    Last Post: 09-14-2007, 08:56 AM
  3. Toto Aquia - 11 3/4 rough in ok?
    By ss3964spd in forum Toilet Forum discussions
    Last Post: 09-11-2006, 07:41 AM
  4. Help Needed - Neptune Murano/Toto Aquia/Happy D/11" Rough in
    By MarkP in forum Toilet Forum discussions
    Last Post: 06-11-2006, 10:56 AM
  5. Toto Aquia and a 11.25" rough in?
    By JAHarris in forum Toilet Forum discussions
    Last Post: 03-14-2006, 11:52 AM
