Results 1 to 2 of 2
Thread: Williams Dual Walll Heater/Pilot goes off
    Default Williams Dual Walll Heater/Pilot goes off
    Hi there,
    Looks like we have a problem with a Williams Dual wall heater. The heater has been in place for a number of years. Despite numerous attempts to fix the problem, the pilot continues to go out randomly. It may stay on for months at a time, then will simply go off. Once it starts popping off, it is usually not too difficult to relight, but may go off within 10 minutes or an hour. Or, as stated, may stay on for months. Seems most affected in cold weather...
    Thanks for any help!
    Dennis
    What type and where does the flue go? You may need to extend or cap the flue chimney top to prevent a gust of wind from blowing it out. Another possibility is, can you relate when this happens to a particularly cold day or a day when you are using a lot of gas elsewhere in the house? It could be a supply issue that only shows up when lots of other things are using gas.
  1. Water heater pilot light goes out
    By Coldnwet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2008, 01:45 PM
  2. Sherwin Williams or Ben Moore
    By weather777 in forum Remodel Forum & Blog
    Last Post: 11-05-2008, 09:35 AM
  3. Reliant gas water heater pilot
    By Guest in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2008, 08:30 AM
  4. Gas Water Heater Pilot Question
    By Quibbley in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-01-2006, 07:27 PM
  5. Brand new water heater pilot goes out often
    By mrwiegand in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-23-2005, 03:10 AM
