Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: how to fine tune 30/50 pressure switch?
    DIY Senior Member billfig's Avatar
    Feb 2011
    upstate NY
    Default how to fine tune 30/50 pressure switch?
    Square D with lever, has 2 posts for adjustment, the center proudest stud for Range"turn nut down for higher cut-in, or up for lower cut-in. I thought this one is for raising overall pressure??
    lower stud off to side is Differential "turn nut down for higher cut-out pressure or up(loosen) for lower cut-out-so this one is used for overall higher pressure?
    I can't seem to get the pump to come on later-say when she goes down to 30psi? I turned pump off and drained, when gauge hits BAM! switch clicks and gauge drops to 0.
    In the trades WellWaterProducts's Avatar
    Feb 2011
    Northwood NH
    Quote Originally Posted by billfig View Post
    How much air pressure is in the tank?
    Chris Kofer
    h2oguy.com
    Feb 2011
    upstate NY
    exactly 28 lbs. empty.
    Feb 2011
    NW Ontario, Canada
    The big spring (proudest) if tightened, will increase both the kick-in and the kick-out. The small spring if tightened, will increase only the kick-out.
    Feb 2011
    upstate NY
    well I currently have it at 34-35 kick-in and 52 kick-out using trial/error since logic doesn't seem to work? sure would like to get the spread further apart...wish it were that easy!
    I would love to see it in operation at say 30-55...
    Moderator valveman's Avatar
    Mar 2006
    Tightening on the small adjustment screw will widen the bandwidth between on and off. But why do you want to do this??
    Feb 2011
    upstate NY
    well I adj.the tank psi to 28 per a 30/50 sw. and would like to at least try the 30 cut-in....then an extra 5 for the heck of it.
    I just can't seem to ever get that cut-in below 34?
    Feb 2011
    Northwood NH
    I'm sure of your overall strategy here but here goes:
    Loosen the nut on the tall spring a few turns, that will lower the cut-in
    Tighten the nut on the short one to raise the cut-out.
    Chris Kofer
    h2oguy.com
    Mar 2006
    Then loosen on the big screw to lower the cut in pressure. (one round = 3 PSI) Most people want an extra 5 or 10 pounds "for the heck of it" to try and get a little extra run time. All you are doing is overstretching the bladder and shortening the tanks life. When I go to a pump system where someone has widened the bandwidth, I know they are trying to reduce the cycling.
    Feb 2011
    upstate NY
    Quote Originally Posted by WellWaterProducts View Post
    Yea I kinda tried it with my valve closed to house and switch off but on recheck, I had a time getting pump to start?
    I'll go try it again with pump on, it's almost like I could take the nut right off of the range/main stud, once the gauge drops to 34 it clicks and water drain just immediately stops too
    So the 20psi differential rule is a "Golden Rule" to strictly adhere too.....
    Feb 2011
    NW Ontario, Canada
    You can keep the 20 PSI spread and increase the cycle time a little by increasing the pressure. GPM from the pump generally diminishes with pressure so at 20-40, the GPM will be more than at 60-80. The GPM through the fixtures however increase with pressure, so your showerhead will put out more GPM at 60-80 than at 20-40. The two combined will result in the pump cycling less during a shower.
    Feb 2011
    upstate NY
    I loosened large/range adjuster 3 twists of ratchet(a tad over 1 full turn) no change. I then loosened it another 3 twists, no change?
    I noticed when draining gauge gets to 35 and 3 things happen, gauge drops to 0, cut-in clicks and drain is empty(and closed by me at that point) then gauge slowly begins ascending then at 20 it jumps to 40 and pumping begins? Goes to 51psi and stops
    Feb 2011
    upstate NY
    wow thats pretty interesting! But running a 40-60 must be more taxing on the submersible pump? Why all the different pressures?
    Feb 2011
    NW Ontario, Canada
    If the pressure drops really fast from 35 to 0, it probably means that the precharge on the tank is too high and that at 35, there is no more water in the tank.
    As for how the pump surges from 20 to 40, again if the bladder precharge is too high, there is nowhere for the pressure to go until it exceeds the precharge. Also, the pump uses pressure to make pressure so you will notice a performance curve.
    Feb 2011
    NW Ontario, Canada
    I don't understand the question. The higher the pressure the less the 20 PSI differential is felt. Taking a shower between 20-40 is medeocre at best. Taking a shower at 60-80 is wowzers. Somewhere in between is where one settles depending on personal preference versus pump capacity.
  1. Replies: 0
    Last Post: 01-31-2011, 06:24 AM
  2. No water pressure in one tub, rest of house fine
    By lbet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2008, 11:00 AM
  3. Low Water Pressure to Shower only - Tub fine
    By Bumfuzzled in forum Shower & bathtub Forum & Blog
    Last Post: 01-11-2008, 04:40 PM
  4. Mstr Bth Shower Pressure Low - Fine Elsehwere
    By cookpr in forum Shower & bathtub Forum & Blog
    Last Post: 09-26-2007, 07:49 AM
  5. lose of hot water pressure cold is fine
    By ooootis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-24-2006, 09:58 AM
