I live in a 100++ year old farm house, a few weeks ago I was outside and noticed the well pump was rapidly cycling on and off. I went in inside to find the wife doing a load of wash. I thought this was not right the way the pump was cycling, so the next day I called a local well guy in the phone book. He came out within less then a minute said our tank was waterlogged.
We have a 40 gallon tank made in 1997 by well-mate tank. The well guy recommend going to a 60 gallon tank to keep the pump from cycling less. He wants $1200-1300 to install a new 60 gallon tank. I think that his price is very steep. Looking around the net a replacement tank just like ours, same make and model and size is only $300, and a replacement air cell is less than half of that. So my question is if I hired the well guy to put in a new 60 gallon tank would I be getting hosed on the price?
Here is a picture of the current set up in our well pit. There are two tanks, 1 steel and 1 fiberglass.
The current set up does not make a lot of sense to me and the well guy could not put it into laymen terms either. It's just a hokey set-up but apparently it seems to work. (or did at some point in time) The galvanized water line comes from the well (you can see this in the lower right side of the picture), it goes into the galvanized tank about a foot off the ground on the right. It comes out of galvanized tank on the left side and into a T. If you follow the T down it goes over to the fiberglass tank and that's the only in or out on the fiberglass tank. If you follow the T up (just below the shut-off valve) it goes out the side of the well pit and that is what feeds the house. There is also a small water line that runs along the backside of the fiberglass tank that goes to an outside water spigot. The black hose that you see coming off the T and the whole other mess of fittings feeds a couple water hydrants out by the barn.
The price above I mentioned for the well guy only includes disconnecting the modern fiberglass tank and installing a new one in its place, and leaving the old galvanized tank still hooked up. He said the whole system needs to be ripped out and updated which would be a T&M job and could run anywhere from $600-$700.00 for parts and labor in addition to the tank price he already quoted me.
I have done some reading on the forum here before I joined. It seems like now would be the time to install a CSV valve and small tank. I've read several valveman posts and it seems like this is the recommended thing to do. We're not sure how deep the well is. The well guy said he did not drill it but given the area I live in and his experience is that it's probably 100'-150' well. I asked him what the capacity of the pump but without pulling it he couldn't tell me anything for sure.
Is this a project I can tackle as a homeowner or do I need to hire a professional to do the job? There is a family of four that lives in the farmhouse, not sure of average water usage monthly, but each person takes a bath/shower a day with basic washing/cleaning usage. There is no livestock that need watering. The only real extra water use would be for the large garden my wife wants to put in this summer. Thanks for any tips or suggestions you may offer for our current system.
Matt
Matt
