Results 1 to 4 of 4
Thread: Do you pay the plumber-roto rooter man?
    Dec 2009
    northfork, california
    Default Do you pay the plumber-roto rooter man?
    Rental. septic system. Plugged main line in the crawlspace. I usually open a cleanout and jet it with a garden hose.
    Subbed it to the plumber for 145$. He pulled a toilet and ran his snake - 100'
    No result, so his report is that he thinks the snake is in the tank and the pipe is clean.
    I had doubts, but the Septic was pretty due for a look. Tank was NOT backed up. After 150$ in digging and $425 in pumping, kicked the inlet tee on the tank.
    And there came a nice plug about 6" long of snot that the plumber had pushed right to the inlet tee. He was 6" short of being worth his $145.
    So how would you deal with that? How much snake should a guy have if he calls himself a drain cleaner?
    And should he have known he did not pass the 90' tank inlet?
    YOu have as much as you need. I have 150' on my truck. You decide where the tank is and then go 10' further, assuming your snake will make the turn at the baffle tee and go downward, and not up against the lid which sometimes happens. Snaking a septic line takes about 50% experience and 50% luck to know WHEN to stop.
    Nov 2010
    Maine
    I keep 250 feet of 7/8 for my K60 that's about all I can handle by myself.
    If ANYONE installed a sewer with more than 125 feet between cleanouts, much less 250', it would be time for a backhoe to install them.
  1. Undercover BOSS: Roto-Rooter Sunday 4/5/10
    By Terry in forum Plumbing Forum Discussion & Blog
    Last Post: 02-19-2011, 08:10 PM
  2. Rota Rooter independent contractors??
    By brother in forum Drain Cleaning
    Last Post: 02-19-2011, 08:04 PM
  3. ROTO Glove
    By Hairyhosebib in forum Drain Cleaning
    Last Post: 06-26-2010, 08:05 AM
  4. Rota Rooter independent contractors??
    By brother in forum Plumbing Forum Discussion & Blog
    Last Post: 02-10-2009, 04:25 AM
  5. Roto Rooter Strikes Again
    By Cass in forum Plumbing Forum Discussion & Blog
    Last Post: 12-03-2008, 04:10 AM
