Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: First chlorination; How do I open my well?
    DIY Junior Member
    Feb 2011
    NC
    Default First chlorination; How do I open my well?
    Hi everyone,
    I need to do chlorination of my well, I read the instructions, and everything seems clear except a tiny thing - how do I actually open the well???
    As you can see One of the screws is right below the water pipe; also there was a plastic PVC seal on top of an air pipe (???) which fell off... Can I put bleach through that pipe?
    Nov 2010
    Maine
    Spin the sillcock off and dump it on down
    DIY Junior Member
    Feb 2011
    NC
    you mean I need to remove the sillcock, and leave the well seal with the connecting pipe as is??? Sorry
    Dec 2009
    northfork, california
    Do not remove the hose bib. You would be pouring chlorine into the well outlet pipe, which should be impossible due to the check valve.
    You are all set for chlorinating and recirculating. The recirc part is the most important.
    Add the correct amount of chlorine liquid through the broken off poly pipe fitting threaded hole, into which you will place a nipple riser and a hose thread adapter.
    Connect the hose bib outlet to a washing machine hose on one end and the other end on the new riser where you poured the chlorine. You could even add another hose bib on the new pipe riser as your closeable "inlet" port.
    Run water down the well for perhaps a half hour or more. shut it off.
    Now run water at all taps until you smell chlorine. Shut it down and let it sit 24 hours. Likely repeat. Flush it out good after each process.
    You dont need to fool with the cap, but you need to get that cap SEALED and covered.
    Jan 2008
    Ballvalve is right, there is no need to fool with the well seal. Work through the vent fitting.
    Unless you normally have a doghouse over the well, that electrical junction box should be replaced with one approved for wet use.
    Nov 2010
    Maine
    sorry guys I had a major brain cramp there, indeed filling it through the sillcock opening would not work Duh..... yes, use the vent.
    DIY Junior Member
    Feb 2011
    NC
    Thank you everyone! Especially ballvalve - thank you for the detailed answer.
    Jan 2008
    Virginia Beach, VA
    Ballvalve said it best. Lastly, replace the broken off poly pipe fitting with a new vent pipe. The well needs to be vented.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    When chlorine is used to disinfect water there is a reduction in the ability of the chlorine to disinfect; call it chlorine demand. Let's say there is 200 ppm total chlorine at the beginning of the disinfection process, the end of running the water back down the well. Let's say there is 1 ppm of iron, that takes 4-5 ppm to oxidize the iron, 200-5 = Free chlorine of 195 ppm. Any manganese uses part of the total chlorine as all the killed bacteria does also.
    Disinfection does not work well or at all if the water is dirty. Oxidizing iron, manganese, H2S etc. etc. and killing bacteria all have a chlorine demand that also causes dirty discolored water.
    To get rid of the dirty water you must flush it out of the plumbing or you're wasting your time and probably will find you still have a bacteria problem after shocking and retesting. Flushing the dirty used chlorinated water out of the plumbing draws in fresh chlorinated water from the well and if you do that for like 10 seconds at cold water fauctes only every 15-30 minutes over a few hours, you eventually find clear water with a strong smell of chlorine in it being used in the plumbing instead of dirty water. That accomplishes a true complete disinfection of the system.
    Drawing chlorinated water into the plumbing and letting it sit stagnant for many hours, like 24, and then running off all the chlorinated water (not into a septic system) does not.
    Dec 2009
    The health dept around here suggests 24 hours. If I had a lot of old steel pipe I would do a lot less time.
    I one time got a house to pass coli that had pumped dirty crud water for years. But it loosened up the insides of the old pipe so much that I finally repiped the place with pex. Would have needed it anyway however.
    I have my doubt about that amount of 'spent' chlorine hurting septics. I think 20 gallons of pool chlorine would not begin to kill off the bugs in the average tank and field. And it would never make it to the field anyway.
    Yeah and the government is wrong on a lot of other things too. For years I did a lot of shocking of wells for the VA and FHA per "government" suggestions. Many showed contamination after shocking so I decided to come up with a better way and came up with what I described above by experimentation. I found it works best by doing follow up testing up to 2-3 weeks later and rarely found any problems as I used to with the "government" and others' suggested way. It works on galvanized too.
    The water in the well has free chlorine in it and that can harm a septic or it should be assumed that it might, so I advise not putting it in a septic system. And some guys use way too much bleach by a number of gallons.
    In the trades WellWaterProducts's Avatar
    Feb 2011
    Northwood NH
    This arrangement would be much nicer with a pitless adaptor and a well cap. I see that it's in NC so the line would not have to be buried but having the cap and the pump support independent of each other is more service-friendly.
    Moderator valveman's Avatar
    Mar 2006
    The well is already open. Any bug or animal that finds its way to the top of that broken fitting in the well seal will be sucked down into your water. This is probably WHY you should chlorinate the well. After you get the well and pipe disinfected, make sure you put two elbows together so that open fitting points down. Then use a good screen over the inlet to the first elbow to keep out the critters.
    Dec 2009
    Nobody vents wells around here - whats the deal?
    Feb 2011
    NW Ontario, Canada
    My well cap is not airtight and I doubt the OP's is either.
  1. In-well Chlorination?
    By kplank in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-07-2010, 08:49 PM
  2. Brown rusty water after chlorination
    By Pat OT in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-23-2009, 09:13 PM
  3. Open Hot
    By Jed54 in forum Electrical Forum discussion & Blog
    Last Post: 07-09-2009, 06:53 PM
  4. In-well chlorination
    By goat1of2 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-22-2009, 05:21 PM
  5. chlorination question
    By angler_management in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-09-2005, 10:53 AM
