The problem you'll have is that all new gas WH must have a new burner assembly that is immune to combustable vapors (FLIR?). This typically can add 6" or more to the height of the tank for the same volume WH. So, it's highly unlikely you'll find one the same height. Whether a tankless is a decent option would depend, but in CO, it may be fairly costly. You'd probably have to upgrade the gas service line, and the cost of the things aren't that cheap, either. Depending on how far you need to go to properly vent it, the special SS vent lines are quite expensive. Then, you're incoming cold water supply may mean winter HW output is either depressed, or you need a larger unit than say someone in FL, where the incoming winter water temp is tepid already, rather than close to freezing. On a tankless, ALL of the water is heated as it passes by the heat exchanger, so the more you need to heat, and the bigger the change in temperature, the bigger the unit you need. It's one thing to use a hot water dispenser to fill a coffee cup, and another to take a decent shower...
