Thread: Connecting a 1-1/4" fleck 7000 bypass valve to water supply
    DIY Junior Member geod's Avatar
    Feb 2011
    Nevada
    Default Connecting a 1-1/4" fleck 7000 bypass valve to 3/4" water supply
    Hi,
    I just got a new water softener in to replace our old sears kenmore water softener. It's has a Fleck 7000 control valve with a 1-1/4" plastic bypass valve. The new water softener bypass valve came with two plastic 1-1/4" male threaded plastic fittings to connect to the water supply.
    My problem is that currently the kenmore is connected with two corrugated copper hoses that are 3/4" on the water supply side and 1" on the water softener side. I've looked in home depot, but couldn't find anything to connect my 3/4" water supply to the new water softener's 1-1/4" threaded connections.
    Any suggestions on where I can find a connector.
    geod
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Are the copper hoses threaded on both ends? If so, you can convert to pvc simply by attaching a pvc female adaptor on the incoming line then bushing up to 1 1/4" and attach a female adaptor to the bypass valve. Do the same on the soft water side.
    Dec 2009
    Alaska
    Look for a plumbing supply house for the part that you are looking for.
    You might find the 1 1/4 to 3/4 in one part or you might have to step it down in 2 or 3 parts per side..
    Feb 2011
    Nevada
    Thanks for the replies. I visited the local plumbing supply house and got a 1 1/4 to 1" corrugated stainless steel hose along with a 1" to 3/4" bushing. I've got the softener hooked up and its working great.
  1. Fleck 7000 Problem
    By ArayT in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-03-2011, 11:04 PM
  2. Softener hookup issue - 1" bypass, 3/4" Main
    By adawg in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-23-2010, 02:09 PM
  3. Help Programming a Fleck 7000 SXT
    By batboy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-03-2010, 06:43 PM
  4. Supply to 3/4" valve?
    By fjordrr in forum Plumbing Forum Discussion & Blog
    Last Post: 01-14-2009, 08:01 AM
  5. fleck 7000 or clack ?? help
    By gerrythegreat in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-24-2006, 08:30 PM
