Results 1 to 5 of 5
Thread: Stainless Steel Tank and Copper Plumbing
    DIY Junior Member G. Mack's Avatar
    Feb 2011
    Michigan
    Default Stainless Steel Tank and Copper Plumbing
    New to the forum I am, and have a unique application. I have a heat pump (free heated water) and have a super insulated 170 gallon stainless pressure tank that I want to store heated water from H.P. and a future solar-tracking collector. This is a used water storage tank in great condition. It will have a large expansion tank and t/p relief valve on the unit.
    My questions are:
    1. What is the best connection between copper and stainless for corrosion-free longevity?
    Dielectric, brass, what? No galvanized, right?
    2. I am estimating water from solar to rise to 120+ degrees. With no real heating element in the tank, do I still need some kind of sacraficial element (rod) in the stainless tank?
    You could use either Stainless or copper flex water heater connectors.
    Copper can be directly connected to SS without problems. The only time you'd get corrosion is if the thing wasn't put together properly and it leaks, then the water may leave mineral deposits when it evaporates.
    In the Trades ilya's Avatar
    Dec 2009
    Akron Ohio
    That sacrificial element is called an anode, and I don't see the need in a stainless tank.
    not a licensed plumber
    The anode has NOTHING to do with whether there is an element in the tank or not. The tank material determines whether you need one, and as stainless tank should not require an anode.
  1. stainless steel
    By chaoster in forum Remodel Forum & Blog
    Last Post: 03-18-2009, 08:21 PM
  2. Braided Stainless Steel or Copper for my Water Filter and Icemaker?
    By roegs in forum Plumbing Forum Discussion & Blog
    Last Post: 11-19-2008, 04:28 PM
  3. Copper pipe to steel pressure tank
    By cacher_chick in forum Plumbing Forum Discussion & Blog
    Last Post: 04-25-2008, 04:56 PM
  4. Pex-copper rings -stainless steel clamp
    By JOE1934 in forum HVAC Heating & Cooling
    Last Post: 06-30-2007, 12:24 PM
  5. Connect Stainless Steel to PVC
    By srizakari in forum Plumbing Forum Discussion & Blog
    Last Post: 12-14-2004, 05:43 AM
