Results 1 to 9 of 9
Thread: what are some tricks to tighten chrome/nickel etc pipes
    DIY Senior Member bbillcee's Avatar
    Feb 2007
    NY
    Default what are some tricks to tighten chrome/nickel etc pipes
    i see some guys use a pipe wrench close to the wall behind finish plates, duct tape around the pipe, what do u pro's do?
    If it's a shower head, I attach the shower head, and then I can hand turn it,
    I can hand turn tub spouts, I Have never needed anything else.
    And shutoff valves normally have flat sides on them for a smooth jaw wrench.
    Most plumbers are strong enough to do most of these things without tools, therefore saving the finish on your fittings.
    Feb 2011
    NW Ontario, Canada
    Never used duck tape but have used electrical tape. Sometimes I use a rubber strap wrench. On something like a tub spout, I may put a screwdriver handle or wood dowel in the outlet for extra leverage. On something like a wall union, I will use an allen key of the right size in the outlet to get leverage.
    Unless you use a strap wrench and rosin, there is almost no way to prevent wrench marks on finished surfaces. Usually, I tighten a nipple by turning the fitting on the other end of it.
    Jul 2007
    USA
    I have had some success padding the surface with an old rag, then gripping and turning.
    Default pipe
    When you wrap a pipe with anything before tightening it, the force you apply is limited to whatever the material will hold until it starts to slip, and that may NOt be enough to prevent leaking.
    Business owner, Plumbing Tech. Beantown Plumber's Avatar
    Feb 2011
    Boston, Massachusetts
    I have a set of internal pipe wrenches that I use all the time. Theese things are very handy, and perfect for chrome. They leave no marks at all because they bite on the inside.
    Beantown Plumber @ Pristine Plumbing and Heating http://pristineplumbingandheating.com
    "Business is like oil, it won't mix with anything but business" - J. Graham
    Dec 2009
    northfork, california
    Piece of slit heavy hose clipped over the pipe and channel locks.
    In the Trades ilya's Avatar
    Dec 2009
    Akron Ohio
    Beantown, I love internal wrenches but can't find good ones that last. Got a good brand name for me? Thanks!
    not a licensed plumber
  1. Nickel parts for Moen Chateau 6990 Roman Tub Trim
    By Tony2 in forum Shower & bathtub Forum & Blog
    Last Post: 04-14-2010, 06:30 PM
  2. Does brushed nickel hold up as well as chrome?
    By JimFrandeen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2008, 08:01 PM
  3. seal chrome vanity pipes
    By jean-karim in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-12-2008, 02:18 PM
  4. Leaky Brushed Nickel Nipples
    By scottg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-03-2007, 10:23 AM
  5. removing chrome drain pipes
    By jkduab in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2005, 06:08 PM
