Results 1 to 7 of 7
Thread: Oil Funance Chimney issue
    DIY Junior Member theMezz's Avatar
    Feb 2011
    Central NY
    Default Oil Funance Chimney issue
    A chimney to a oil furnace collapsed, and I see the local heating contractor installed a power vent http://s3.pexsupply.com/manuals/1260..._PROD_FILE.pdf with am exhaust pipe that goes outside and just about the ground (not a real chimney)
    Anyone hear of this before? It's a high snow area - won't it get covered with snow? They had to shovel away 4 foot of snow outside to install this.
    Is that code compliance??
    Thank You
    Nov 2010
    Maine
    Very very coommon practice. Make sure to follow the installation instructions for distances to windows, the ground, doors and such.
    Feb 2011
    Central NY
    here is a photo
    The exhaust and intake usually are supposed to be above the snow level. It depends on the specifics of the installation manual. As noted, it is also very important about where it terminates verses things like door, windows, and other intakes and exhausts. This is all spelled out in some detail in the specific device's installation instructions.
    In the trades Dana's Avatar
    Jan 2009
    It also depends on local code. This wouldn't pass code anywhere in MA that close to the ground due to snowpack related issues, but it might be allowed in TX. I'd be suprised if an inspector would sign off on it that way in NY. Buried in snow next to the house the exhuast will find it's way under siding & sheathing, can present a very serious health hazard, even if the location met all other clearance requirements to operable windows & doors, air intakes, etc. .
    DIY Junior Member david_griffin's Avatar
    Feb 2011
    Denver, CO
    When I look at the image I am thinking who was so stupid and installed it in this way and in such country region :-(
    Feb 2011
    Central NY
    Amazingly enough it was installed by a heating company that is very popular and has been around for many years. WTF !
  1. Any issue using Type B vent pipe from water heater back to chimney?
    By vtxdude in forum Water Heater Forum, Tanks
    Last Post: 12-21-2009, 12:43 PM
  2. Chimney Repair
    By Mikeyboy in forum Remodel Forum & Blog
    Last Post: 03-13-2009, 09:37 PM
  3. Questions; gas/oil, chimney, hot water.. ??
    By sarahw97 in forum HVAC Heating & Cooling
    Last Post: 06-30-2008, 04:59 PM
  4. still need reline in my chimney?
    By lmei007 in forum HVAC Heating & Cooling
    Last Post: 11-18-2007, 03:57 PM
  5. Chimney relining question
    By mln in forum HVAC Heating & Cooling
    Last Post: 08-22-2007, 07:55 PM
