Sorry, I cannot answer your first question but as for this one, I think it could have a propensity to trip. All my outdoor recptacles are GFCI and when I use them to power motorized tools like saws and drills, they easily trip when shutting off the tool. I think it has to do with the collapsing magnetic field on the motor coils and/or the motor becoming a generator. Possibly not all GFCIs are created equal and YMMV.
Should you have some tool that is tripping your outside receptacles then your tool needs attention or replacement. The GFCI device is doing what it was designed to do.
What is a YMMV?
If it is a regular wall switch then it should be GFCI protected. Don't most disposers have an air coupled push button?
I do believe you have crossed over the boundary of knowing and guessing or inserting opinion in a matter in which you have little or no knowledge. Neither the US or Canadian codes require a switch to be ground fault protected,
Not really. The operative question was "should", not "must" as was my advice. There is no point in me quoting Canadian Electrical Code to the OP who lives in NY.
This makes me wonder just what your point is in this post. Why do you think the switch should be GFCI Protected? In your next statement you say that the Canadian code requires it to be protected but refuse to post a quote from the code.
If you can ground one hand on the sink or tap and reach the unprotected switch with the other perhaps wet hand, common sense dictates that a GFCI "should" be used. Canadian code may dictate it too. When I built my home 12 years ago, I did my own wiring and read through the code books at the time, but am too lazy to scour through it now.
If the sink is not in contact with earth is some matter how is it grounded? I think you are grasping at straws here as you sure don’t understand the concepts of grounding and bonding.
1.
Here is an excerpt from my google search. GFCI Protection of Kitchen Counter Receptacles
Rule 26-700(12)
The 2002 edition of the Ontario Electrical Safety Code includes an Ontario amendment to Rule 26-700, which requires Ground Fault Circuit Interrupter (GFCI) protection for Kitchen Counter receptacles effective January 1, 2003. The new Subrule (26-700(12) states that effective January 2003:
(12) Receptacles located in kitchens and installed within 1 m of a kitchen sink along the wall behind counter work surfaces shall be protected by a ground fault circuit interrupter of the Class A type.
Appendix B note: Distance of 1 m is measured from edge of kitchen sink.
The following guidelines shall be used for consistent interpretation and application of this new subrule effective January 1, 2003.
1. This rule applies to all receptacle installations located within 1 m of a kitchen sink along the wall behind counter work surfaces where the plans or application for inspection is received on or after January 1, 2003.
Dang if I can find one word from this quote that says a “switch” is required to be GFCI protected. Shucks I only see the requirement for countertop receptacles which wouldn’t include one under the cabinet.
I realize the outlet is "Under" the counter but the switch presumably will be "Above" the counter. I'm sure I can find some code reference to a light/fan/switch near a sink or bathtub/shower etc. We GFCI protect anything that is within easy reach of a sink/tub/shower/etc. Why would a disposer be any different?
But your code section says nothing about a switch. The switch is something you have come up with. The receptacle for the disposer is under the sink not above the sink.
We see here in a lot of new construction that the light switch is on the outside of the bathroom. Mine is on the inside, albeit protected by GFCI. The same with my laundry room. Now, I stopped short of using GFCI on the washer because it would likely trip it. I don't generally operate the wash machine while I have a hand in the sink or on the tap. A garbage disposer however is more prone to be operated whilst touching the faucet which is why they came out with those air switches. If you guys want to build to minimum code, that's your choice.
I would choose not to use a GFCI but then I would use an air switch.
I say that if this is true then those living north of the boarder have completely lost what few brains they had left. As to the washing machine if the receptacle is located within 6 feet of a sink then the washing machine receptacle would be required to be GFCI protected. Should the washing machine trip the GFCI the there is something wrong with the washing machine.
All this bull waste of collapsing magnetic fields tripping a GFCI device is some idiots way of trying to explain something they know nothing about. It simply doesn’t happen.
