Results 1 to 7 of 7
Thread: two capped copper pipes protruding from concrete slab in basement
    DIY Member Pickngrin's Avatar
    Sep 2005
    Massachusetts
    Default two capped copper pipes protruding from concrete slab in basement
    My home was built in the late 1950s. I've got two copper pipes (see photos) protruding from the concrete slab. When we bought the house, we were told that they are not used for anything. Is there a way I can verify this so that I can know for sure that they are safe to cut and cover up?
    Jan 2008
    The top picture looks like it is coming through the wall, not the slab. ??
    If so, go outside and start digging next to the foundation and see if you can tell where they are going.
    You might have a fuel oil tank or an old propane supply connection there.
    Sep 2005
    Massachusetts
    I thought that was the slab. When we bought the house, we had received written confirmation that there was no below-ground oil tank.
    There may have been one, and when it was removed, they left the pipes in place, and only removed the tank. You could take the plug out, but if it is connected to water, you'll get wet! At least that would tell you if it is connected to anything.
    Sep 2005
    Massachusetts
    Is there a special tool (hm, this is a stupid question, isn't it?) to remove those plugs with the raised squares? My pipe wrench isn't doing it.
    You'll probably need two wrenches: one to hold the fitting so you don't twist things too badly, and a second one to unscrew the plug.
    Loosen the plug, but do not remove it immediately until you see if anything leaks out as it gets looser.
  1. Is this a basement drain capped off?
    By tperkcincy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-03-2007, 07:56 PM
  2. Rerouting Drain pipes in concrete slab: DIY or call a pro?
    By Andy Ring in forum Remodel Forum & Blog
    Last Post: 04-30-2006, 07:56 AM
  3. Need to drill into slab, how to avoid copper pipes?
    By Collin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-01-2006, 02:34 PM
  4. Why do I have a vent pipe capped off in the basement?
    By BrianF in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2005, 12:15 PM
  5. Testing PVC Pipes Under Concrete Slab
    By Fran in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2005, 03:30 AM
