Results 1 to 2 of 2
Thread: need help with a leak
    DIY Junior Member Drake25's Avatar
    Feb 2011
    Virginia
    Default need help with a leak
    My kitchen faucet is leaking. i cut the water off from the shut off valves and noticed it only leaked when the hot water side was on. i left it off for a few days till i could solve the issue but now it runs slightly even with the valve shut off. ive checked the rubber seal under the knob and noticed it was damaged so i replaced it but while doing so the water still continued to run even without the cartridge. not out of the faucet but from where the handle goes. what should i do?
    I think you have two problems, first, the shutoff valves under the sink seem to be leaking (i.e., don't shut off completely). I suggest replacing them with 1/4-turn valves. This may be easy or hard, depending on how they are currently attached to the pipe. If they are compression or threaded on, it's fairly easy. If they are soldered on, then you need some tools and skill. Then, a picture or brand/model of the kitchen faucet would help identify where the problem is. There are thousands of versions in different configurations, so what works for one may not work for the other.
  1. Tub leak, stain in ceiling below - How to find leak???
    By Chuck1026 in forum Shower & bathtub Forum & Blog
    Last Post: 10-03-2013, 07:22 PM
  2. hot wtr leak in slab AND sewage leak possible?
    By dzgrrl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-15-2009, 02:02 PM
  3. Foot Valve leak vs. supply leak
    By bikeguy18974 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-16-2008, 05:09 PM
  4. Leak - Help
    By sharonfrank in forum Shower & bathtub Forum & Blog
    Last Post: 08-05-2006, 04:24 AM
  5. What causes a tank to leak and then not leak
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2006, 08:01 AM
